Well this sucks
8:46 AM
I took .060" off the base and set squish. After bringing the exhaust up, I ended up at 105. Xfers are now at 120. Intake 77. I'm happy with that. I was gonna do an 044, but the crank was broken in half. It's a 12mm 440 with a KS slant fin d jug. It'll probably wear a 20" bar and chain
mdavlee
Hillbilly grinder
8:46 AM
TN
That's a lot. I think I took .045" off once and thought it was too much. I like 102 on them.
CR888
10:46 PM
Australia
Keep us posted with pics of mods as you go so we can critisise, call you names and tell you your saw won't work and stuff. Nah kidding I think you will do well and gain 40% if the after vid is in snellerised wood.
8:46 AM
Yea I was thinking that too. The base is about .220" thick. And it's still .050" from free porting. It's sort of a test bed at this point. The bearings and crank were good. Cases are like new. I'll put a new ring in it and seal it down and see how it turns out.
mdavlee
Hillbilly grinder
8:46 AM
TN
Compression will be 240 or better I would think with that much off and low exhaust.
8:46 AM
Pfft. I could file snellerized rakers and cut 40% faster with a stock saw. Pretty easy to get rpm in the cut with a saw
8:46 AM
My squish isn't that tight. I'm at .028. The outside cutting edge of my mandrel wasn't straight after turning out chunks of rings and bearings from the sb. Thought I was head slapping. Took me .020 worth of scratching my head to figure it out. I couldn't see it til I put a ring up into the bore and the ends were touching and it wouldn't go all the way up in. Pissed me off, really. Learning
8:46 AM
Been there and done that with the ridge. That's why I took .054 out of an 036 band. Thought it was a head slapper when it wasn't.
I'd raise that exhaust too. My 10mm 044 has a 102* exhaust, .040 from the band, and it's at 220 psi.
8:46 AM
Sorry for the lack of updates. I've been working on drywalling more than saws lately.
I was able to get all of the dent out of the top of the exhaust port. Compression is 205 on a new caber and 1/2 tank of fuel through it. I ended up leaving the ex at 105, but with a bit more squish to help keep the compression down. It'll probably hit 215 when it's broke in. The fingers combined with the low exhaust help it pull like a freight train with a 20" bar on it. I need to get some logs here maybe tomorrow and I'll video some cuts with it.
jmssaws
Banneded
7:46 AM
I have a new one you can have if it will work.
I have a good 12 mm complete crankcase with the fuel tank and handle bar that I'd part with.
sefh3
8:46 AM
MI GO BLUE!!!!
Ouch. Looks like someone used a screwdriver for a piston stop. Seen that many times. I'm working on an 028 that was very similar to that.
