Weak 026
Mark71gtx
11:40 AM
Fuquay Varina, NC
The owner sent me a bag of filters when he dropped off the saws. He will not let his guys work on the saws at all. All of the filters he brought were for 260's. I didn't want an open hole for crap to get in so I tried to clean the old filters as best I could. Anyone plug the hole and use 260 filters on 026's? If so, what do you use for plugs?
paragonbuilder
11:40 AM
Norwich, CT
View attachment 21772 This is how bad a 026 filter sucks!!! I am no less than anal about keeping my stuff clean, and this is what an 026 air filter that was kept religiously clean on the outside, looks like on the inside. Someone explain to me how this got through?
Wow! Gotta love my huskys filtration. That's terrible!
Tpagel
10:40 AM
Central IL
I read on here guys gluing in foam ear plugs.
I am going to try it myself as soon as I get the short 034 type tank vent for my 026 and use the cheap 260 filters.
sefh3
11:40 AM
MI GO BLUE!!!!
Check the clutch springs. Make sure they are tight and not loose.
jake wells
no longer here
10:40 AM
ky
sounds like a clutch problem to me.
sefh3
11:40 AM
MI GO BLUE!!!!
Also make sure the spur and chain are the same. .325 spur and 3/8 chain will cause the same issue.
Mark71gtx
11:40 AM
Fuquay Varina, NC
There was some of the "bar, chain, and sprocket" confusion going on with these saws. I will check into it too.
Mark71gtx
11:40 AM
Fuquay Varina, NC
I am implementing an "everything takes the same length, pitch, and gauge" setup for them now. All saws will wear 20" .325 of whatever gauge he currently has the most of. The only saws that will be different are the two 660's wearing 36" 3/8" bars. I will tell him to upsize them to .404 when the current bars wear out. (The bars are roller nose)
Mark71gtx
11:40 AM
Fuquay Varina, NC
Good point! Does it feel like it's falling on its face, or like its bit off more than it can chew?
I can have it revving and touch the wood (very dry red oak left behind by a logging operation) and it slows down to a crawl. I can pull it out of the wood and it will free rev like it should. Put it back in the wood and it is almost like I put the chain brake on.
Tpagel
10:40 AM
Central IL
You might check the rim sprocket for compatibility with the drum if you are running one.
Mini drum and a small rim act up in wood ...ask me how I know.
panteliss
5:40 PM
Europe
maybe some extra pictures will help the situation . the most posible is the clutch , sprocket , rim just because the saw works good out of the wood
11:40 AM
You need a 260 AF cover for the back end and a modified tank vent on some models.
Plug comp hole with an ear plug.
