Wanna learn to Port a Saw
EvilRoySlade
What’s my line?
2:29 AM
Michigan
are you still interested in having me port a saw for you?
I'm still interested in having you port a saw for me. I'm just being a lazy ass with a bum shoulder getting it together. It's close though. In a few weeks I'll be sending you a saw with 300 $1 bills for packing.
jake wells
no longer here
1:29 AM
ky
im going to send a replacement air filter and clutch springs with it when i send it because they are both bad.
the old filter has flock missing in spots and the clutch springs are just bad.
Moo's Yo Daddy
2:29 AM
Da Barn
I'm liking this 266 model a lot now.
What are the options on hopping it up?
Bigger cylinder model available for a swap?
Carb?
They seem like nice saws, that's why I'm building one. Duh....
This saw has a cylinder off of a bigger saw. It's like 2 1/4" and not 2" like the one on the saw. Seems just as deep when I measured it.
I made the hole in the muffler bigger. It's hard to turn over. Something is rubbing inside, I added some oil through the plug hole, it didn't seem to help. Put a few pumps of grease in the cylinder through the plug hole, it seemed to smooooooooooth it out a bit.
I'm sure it will wear in, whatever the problem is.
If I'm off on the cylinder base, the piston can tilt back and forth and slide back and forth on the connecting rod pin, right?
