Upper transfer angles
mdavlee
Hillbilly grinder
8:43 AM
TN
Happy new year friend.
8:43 AM
Happy New Years guys.
Now that we've establish that the factory (and some of us) open dual ports a bit earlier in the intake side, how do you make your markings to establish you goals?
I've used a ring and thin sharpie and just cut to the line on the exhaust side and all the way through the line on the intake side. I've noted a thin sharpie line to be about 2*.
I can see a more exact way being to cut 2 different pieces of card stock to different degrees, and then creat a slope of the difference. The stock would have to be recurred and flipped side to side.
So, how do you do it?
mdavlee
Hillbilly grinder
8:43 AM
TN
Eyeball mostly. I use card stock or business cards to set the height. I then compare to the card stock to see if it's straight or not.
8:43 AM
Any tricks on cutting the card stock, instead of multiple trial and errors?
I try to measure the ring through the exhaust port, and then cut the stock, but it can be frustrating.
I've taken a C-hair off of the card and changed timing by 4*.
It's amazing how little it takes.
Also, do you guys make studs for your saw bodies, or do you tighten the jug down each time?
mdavlee
Hillbilly grinder
8:43 AM
TN
I measure with calipers and check and then use math. Mark it out with the calipers. I've not seen one that changed that much in that little. I don't work on 50cc very often. Usually 71cc is my minimum size. Half the time I just hold the just down by hand when I'm checking quick. I pull the rings so no resistance.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
7:43 AM
Provencal, Louisiana
I push a ring up the bore and mark with a sharpie 1° less than my mark , to allow for chamfering and sanding
Keith Gandy
7:43 AM
That card trick is really precise though but ill still mark a degree less and go shy and also reinstall cylinder several times to work up to my mark
mdavlee
Hillbilly grinder
8:43 AM
TN
Those cards have ported about 10 saws there. I throw them in and grind. Might have took an hour for the last 7900 for all the grinding.
Redfin
Meh...
8:43 AM
Central Pa
I push my ring up one degree lower, slide the caliper from sqish to bottom of ring, tighten caliper nut and mark the card with the caliper points.
8:43 AM
What kind of caliper?
Mine won't fit in the bore. I usually port 44-48mm saws
I do have a depth mic
mdavlee
Hillbilly grinder
8:43 AM
TN
My digital dial calipers. Slide it to squish. Write that one down. Slide to exhaust port or transfers and log it. subtract what I want to raise and cut the card. I measure how far 10° right at exhaust opening on the piston. Works out pretty good. You can do it on the intake side for transfers as well. Mark 10° on the piston skirt and measure.
