- 5:43 AM
- Dec 29, 2015
- Strong Island NY
Which angles are we referring to?
Entry angle or opening angle?
I dont trust a ring, sometimes they aint exactely straight, but I will measure with my calipers the next time it is off the saw, or when I grab another cylinderPut a ring in there and draw a line.
It was apparent in Carl's thread on the 661. He did just that.
It was on "Fin's Twins" IIRC
On quads or duals?A couple people told me to open the exhaust side first to purge better. Then the intake side can be 2° lower and still flow good.
That looks like the same as the 661 picture ............ intake sloped towards chamber on intake sideHere you go. You might be able to tell. The intake side is sloped on the roof of the transfer.
Now I be cornfused ............A couple people told me to open the exhaust side first to purge better. Then the intake side can be 2° lower and still flow good.
They're level best I can tell with the piston top when degreeing the saw. The roof is just sloped compared to the exhaust side.That looks like the same as the 661 picture ............ intake sloped towards chamber on intake side
Can be if you put a big chamfer on there. I try to go as small as possible and just break the edge with a diamond coating ball.Maybe I misunderstood the question, the angle at the the plating is from how you bevel/chamfer, no?
I think that's right. It also flows right behind the exhaust so it's partially wasted and partially filling. I think it helps keep the exhaust flowing out more completely than opening the intake side first to cause a swirl which will mix the exhaust up more.No matter how many saws I've done, I still second guess myself, and look for new and different things to try.
Like Mike said on the quad port saws. Opening the exhaust side transfer (main) a couple of degrees before the intake side (secondary) seems to give those saws a little something extra. I'm not sure why, but I have a theory. That transfer passage is larger, so when we open it sooner, we begin to give it more flow inertia.
I got 3 generators that wont energize from the paralleling switchgear ................. HATE to call in ASCO, got any tips ?I succefully confused myself this am. I was trying to find a 250k ohm ground in 8k feet of cable. While converting ohms to distance i was throwing degrees in the mix
I really need to focus.
