HELP! Understanding piston design
STOVE
8:38 PM
Eastern NC
Yes, although it will reduce compression
Pretty common to take a little off the bottom of the skirt on the intake side instead of lowering the port.
Thanks for the responses. Learn something everyday.
Is that a more common practice on clamshells? Due to difficulty getting inside the jug?
Sloughfoot
5:38 PM
Norcal
Not necessarily. Quick and easy on any type, might be less to lose modifying the piston instead of the cylinder. Or you might not want to alter the shape of the port. Problem with clamshells is it costs a million dollars to lower the cylinder to increase compression.
STOVE
8:38 PM
Eastern NC
That’s a lot of cheddar. I’m not looking to do anything to my clamshell cs-400. Just like to learn why things are the way they are.
DillonBuck
8:38 PM
Pa
Maybe not a million.
I did it on a Jonnypoulan for Dad.
.058 squish…. Spent a lot of hours gluing pvc onto EMT, then turning the mandrel(with machined in stops) to cut the pockets with emery cloth. Once it was all set up, it took 5 minutes to cut the pockets. Then had to cut the base to match. 022 squish now. A little grinding to help it push air out of the case, tickled and opened everything. Kept it mild, he tends to lean on a saw, didn’t want him to fry it. We are both happy. A 2036 became a pretty potent 2040 for $100. And more value in labor than two of them cost new.
