STOVE
- 2:06 AM
- Aug 29, 2025
- Eastern NC
CS-400....EchoStihl did this?
That adds up. Can't see the Boxheads in Waiblingen having the innovation.CS-400....Echo
So theoretically could you modify them instead of the jug itself?old school porting when you don't have the tools to raise the ports
Yes, although it will reduce compressionSo theoretically could you modify them instead of the jug itself?
Pretty common to take a little off the bottom of the skirt on the intake side instead of lowering the port.So theoretically could you modify them instead of the jug itself?
Not necessarily. Quick and easy on any type, might be less to lose modifying the piston instead of the cylinder. Or you might not want to alter the shape of the port. Problem with clamshells is it costs a million dollars to lower the cylinder to increase compression.Thanks for the responses. Learn something everyday.
Is that a more common practice on clamshells? Due to difficulty getting inside the jug?
That’s a lot of cheddar. I’m not looking to do anything to my clamshell cs-400. Just like to learn why things are the way they are.Not necessarily. Quick and easy on any type, might be less to lose modifying the piston instead of the cylinder. Or you might not want to alter the shape of the port. Problem with clamshells is it costs a million dollars to lower the cylinder to increase compression.
In old days they modded piston . It was cheaper if someting went wrong.... And piston was lighter ...So theoretically could you modify them instead of the jug itself?
Maybe not a million.Not necessarily. Quick and easy on any type, might be less to lose modifying the piston instead of the cylinder. Or you might not want to alter the shape of the port. Problem with clamshells is it costs a million dollars to lower the cylinder to increase compression.
done just that many timesIt also can be a good way of dialing in timing with a cheap aftermarket piston before cutting on an expensive jug.
