Ultimate 066 combination
cease232
7:16 AM
Montana
If I we're building one out of this stockpile I'd use the short case, poly unlimited,
Mahle non decomp 96,120,82, and I'd go through all the carbs and find the one with the largest metering passage and or venruri.
That's what I ended up doing. I used the wj76. I didn't compare Venturi size though.
Definitive Dave
Piss Rev Mafia Member
7:16 AM
Central Ohio
Crankcase Volume of Various 1122 series saws
Early 064 80ml
Late 064 76ml
Early 066 with oval plug and small crankshaft 76ml
Early/Mid 066 with oval plug and large crankshaft 86ml
Late 066 no plug 92ml
MS660 90ml
Farmertec replacement MS660 crankcase 88ml
cliffs notes version
srcarr52
7:16 AM
Iowa City
Early 064 80ml
Late 064 76ml
MS660 90ml
I've found the early 066 with small conrod bearing to be the best of the ones I've built. Also those tend to have the factory hot rod, non decomp cylinders on them.
Moparmyway
Its just a saw
7:16 AM
In a meeting
That new one i got for you was blue if i remember right and it was never run.
That new one is in the vice now .......... I dont recall seeing the rod blued on either end, my CRS is in full bloom though.
I'll doublecheck later tonight when I get home
7:16 AM
I've seen a couple new ones blue. Maybe it wasn't that one.
