Uh Oh Husqvarna 395
Beer Gut
A Fine Pilsner
1:46 AM
Northeastern Wisconsin
20180106_120054.jpg 20180106_120054.jpg 20180106_120102.jpg 20180106_114732.jpg
Here is the dual port location just held with screw for now no hole yet so can be moved. Also the hole I cut in the tube. I also removed the flap on stock port. Anyone see any issues??
Beer Gut
A Fine Pilsner
1:46 AM
New muffler is in paint now. I did raise slightly no chance chain will hit. I opted not to cut tube at all only the flap at the bottom. That makes a clear path for exhaust to back wall. What comes out stock port we will see. Dual I opened to max the 288 deflector would allow. No we wait
2:46 AM
On a am muffler I cut that flap and the baffle ended up coming apart shortly after. I suspect it lost its structural rigidity as it’s welded on both top and bottom.
Beer Gut
A Fine Pilsner
1:46 AM
Since I have no baseline to go off since I started project after only a little idle run, I think this saw sounds rich. I'm surprised, but hesitant to adjust since I haven't even worked it yet. Saw was well warmed up before vid. This would be new to me to lean it out after mm. Opinions welcome
T.Roller
2:46 AM
Southeast, TN
Sounded rich to me also. Factory specs are 12,500 wot
