Uh Oh Husqvarna 395
T.Roller
11:00 PM
Southeast, TN
Ok guys. I'm used to orange caps you yank out with a drywall screw when slot lines up. What do I do with these???
I left mine intacted. With the proper adjuster tool it's much better than trying to adjust while running with a flat head
XP_Slinger
They’re Just Saws
11:00 PM
Central NY
Those limiters can be defeated. The outer ring is splined to the jet screw head. Compress the outer ring with needle nose pliers or something and remove the jet screw. On the bottom of the ring you will find a extra metal that can be easily removed. Trim it off then reinstall. Don’t destroy the splined portion or its recess because that’s where the tension spring for the jet rides. It will make more sense when you pull one out.
Beer Gut
A Fine Pilsner
10:00 PM
Northeastern Wisconsin
Like what you are saying. Got compress outer female confused on removing metal piece
