Beer Gut
A Fine Pilsner
- 4:40 AM
- Dec 20, 2017
- Northeastern Wisconsin
Wondering what size hole to start with under 2nd port 1/2, ovaled 1/2, 5/apes, oval 5/apes?
I’d hog it out to match the deflector.Wondering what size hole to start with under 2nd port 1/2, ovaled 1/2, 5/apes, oval 5/apes?
Your muffler is stock and mine has a second port now. Not sure what happenedIIRC, I drilled a pair of 1/2" holes almost touching, then used a grinder to make them one large oval-ish opening....and then a pinch more
My 394 is still shacking up with XP_Slinger's saws at his house or I'd look...but going from memory my second port is about an inch tall by about 1/2 to 5/8 wide with rounded ends.
And YOU! You keep those bananananas off my tree-90-feckin-fo!Your muffler is stock and mine has a second port now. Not sure what happened![]()
Last 660 I owned had a 1x1.5" front opening plus the original open as much as possible. It idled fine.It's mind numbing to hear those sizes. If I went that big on a 660 and I've done a few, I'd have idle issues and low end tuning problems.
Ported?Last 660 I owned had a 1x1.5" front opening plus the original open as much as possible. It idled fine.
Different then.. I don't port. Not there yet
Do you find that big openings on them are a benefit? Like 2 1" holes vs 1 1.5"?I have a fleet of 1122's
Most ported, some not
All have gargantuan muffler exits
No idle issues on any (after they were tuned correctly)
Don't see it. HmmIt comes with the OEM full wrap kit that Bailey's sells
And it's not a kickstand....it's a skidplate...for when you are riding your 395 around the moto-x track![]()
I do the original round 5/8 and the 2nd 5/8 oval so close to 3/4. Never had luck bigger. Couldn't imagine going duel 1.25. 660s I only do caps, duel port, and tune. I'll try again some dayI have a fleet of 1122's
Here ya go. I bought this out and it came with the....ahem....skidplate as well.
https://www.baileysonline.com/Chain...t-Full-Wrap-for-395XP-Chainsaws-588946201.axd
Seen that one, didn't see skidplate in pic or description. Looking for one that bolts on. Is it in there just not shown?Here ya go. I bought this kit and it came with the....ahem....skidplate as well.
Crazy how cheap it is, but I assure you they are OEM parts.
