Tunnel porting.
smokepole
7:49 PM
upstate NY
I've got an 026 I picked up a while ago, getting ready to put it back together shortly. Has anyone found any gain from tunnel porting the case. These cases seem to have a very flat shelf into the transfers. Just wondering if grinding a transition trough on each side would produce any gains? I'm not looking to build a race saw, just a woods mod.
Basher
8:49 PM
Canada
I don`t want to loose any more case compression down low as opening up the upper transfers already lowers case compression on my saws but a bit of JB weld/epoxy in the right places restores some of the lost area.
smokepole
7:49 PM
upstate NY
Just wondered if a little notch in the back on each side would help as the crank comes up around. Possible 1 cc or less on each side removed. I would think some of this could be made up by cutting cylinder base or the gasket delete.
mdavlee
Hillbilly grinder
7:49 PM
TN
Look into tree monkeys build threads. You may find something similar to what you're thinking about
