Troublesome MS660
Definitive Dave
Piss Rev Mafia Member
1:05 AM
Central Ohio
I had this happen on an MS270/280. I still have the bad flywheel. I was working on 2 at once, switched flywheel by accident and said "WTF?" When I suddenly had spark with the same coil.
I checked the bylaws and if you don't clearly mark the bad flywheel with a black sharpie you will inevitably try to use it again 20 years down the road :)
treesmith
Tree Hugger/Cutterer
3:05 PM
Straya
Can I derail with another flywheel question?
200t flywheel, is it normal for all the fins to come flying off at high speed?
Haven't looked at it, I would guess foreign object, does anyone know otherwise?
Sent from my SM-G900I using Tapatalk
redoakneck
1:05 AM
Ohio326
I think my 088 has a bad flywheel magnet. Just got a new coil, and still no spark
I took the kill switch wires off, so nothing getting grounded out. New sparkplug wire, spring, and boot. New plugs.
Was working before I took it apart and cleaned it. No trauma, lightly sanded.
I can tell the first magnet is weaker than the second, big difference. Is this likely the problem???
Hate to keep buying parts , but dang, what else could it be???
Ugggg.
cgraham1
10:05 PM
Nor Cal
Is it too late to ask if nmurph 'cleaned' the saw before it was put away?
:aplastao:
redoakneck
1:05 AM
Ohio326
Now I can say I learned something today. AND I googled it and found out you can get a flywheel magnet charger for weak magnets. WHO KNEW? Mind blown. :shot:
Flywheel magnet charger?? Anyone fix a bad flywheel, ever??
redoakneck
1:05 AM
Ohio326
Ordered a new one, hope that is the problem
Hey Randy , headed to Jamestown KY, to go fishing next week, I imagine not real close, right town, wrong state
12:05 AM
I'll have 4 kids in tow, so not likely to slip away for a day to observe the wizard work, should be a great fishing trip!!!
Hope the thunderstorms hold off!!
Durn........I was hope you could show me how to preg check my cows while you were here.
