Kevin White
- 12:31 AM
- May 16, 2016
- App puh latch a Virginia
Hi Guys, Im fresh from Another Site and liking the forum. I do alot of buy, sell, repair and Im quite confident in my chainsaw repair abilities, but I have 2 saws here that have stumped me and I need your help.
I bought 2 Stihl ms360s from a guy and Im having trouble with both. The guy told me that he bought these saws to fix up for himself, but never got around to it. Thats all the history I know. They are both in decent shape with typical wear and tear but not commercial wear. Ill tell you what I have done and let me know what you think.
Saw1 . The guy told me this one sounded weird whenever you pulled the cord. I tore down the cylinder and checked around didnt see anything weird, a little transfer but nothing crazy. I grabbed the crank and pushed up and down, no movement. Didnt see any wear marks on the crankcase and didnt look like anything was hitting. I moved on with the repair and did the fuel line, filter, and kit. The saw starts up, runs and cuts, but sounds like a clanking noise. I have repaired over 100 saws and never heard this noise before. It sounds close to the flywheel but I have removed the flywheel and key to check around for any hitting, but sounds internal. You can hear it a little when you pull the cord, but as it idles, its definetly and knocking noise. I replaced the piston and cylinder with one from the other saw, just to eliminate something, and sounds the same.
Saw2: I did the fuel line, filter, and kit right away. Saw starts up on choke, idles well on high idle, then once I blip the throttle it will start to starve. I can make adjustments with the L needle but seems inconsistent. I took the carburetor from the other saw(it would idle and run consistant so I figured the carb was good) and installed it on this one, and got the same results. To me it seems like an air leak, but Im having trouble pinning it down. I have not done a leak down test on the crankcase. How else could I know if it was seals? Maybe some carb spray?
Sorry for the long post and any help would be appreciated.
