Trimmer Lines Breaking Off Inside Speed Feed
7:53 PM
Today I worked on a patch of golden rod which is a highly invasive plus gigantic weed .These things can get over eight feet tall and as thick as your big toe .I used a micro chain saw to wittle them down to around one foot and a Stihl weed wacker with nylon blades to take them to the ground .A standard line trimmer head could not do that but a blade head can .
12:53 AM
Gotta up the gauge anthe to go ballistic on nasty weeds.
This 3.3mm/.130" square line (yellow, gauge flat to flat) is a bulldozer!!!
And I have just the right line head that can handle it, comes OEM with some sturdy 3.0mm/.118" round line.
lehman live edge slab
Live Action
6:53 PM
Mn
So far the Stihl cf3 pro line has been awsome, cuts well, holds up well and doesn’t seem to weld itself together or hang up in head. Stihl does recommend soaking the line in water 24-48 hours before use.
Partner
12:53 AM
Poland
If you wind too much line, you either won't close the spool 😉 or you have to pull it out manually for some time.
Partner
12:53 AM
Poland
The line is glued together by excess revolutions, the engines reach different speeds, but also the gears - some are faster and others slower
RCBS
Redneck Savant Extraordinaire
7:53 PM
Ohio - The hilly part
I just had it happen two weeks ago. Found that the spool where you loop the line is wearing and caused a bind/break. Have used for a few hours since without problem. I am a T35 user and have been for a long while now. Happy with the Echo orange line. Will trim nicely around the yard but still eat small saplings and brush.
Fleethirte
7:53 PM
Virginia
What trimmer head can handle that size?
Partner
12:53 AM
Poland
The largest 130mm heads are quite massive to withstand this. The Italian Tecomec and Oleomac are popular here. You must know that after such a set, the gear will heat up more and the grease will run out faster
12:53 AM
Most bigger Stihl heads go up to .105 then everyone seems to head into the nylon blade heads or metal grass and weed blades. I’ve never ran or even seen .130 that I can recall.
Partner
12:53 AM
Poland
These are hinged metal
Fleethirte
7:53 PM
Virginia
Speaking of trimmers, I think one of my boys dumped a whole bottle of mix in my weedeater (the little stihl grey bottles)
Fleethirte
7:53 PM
Virginia
Echo srm 3800.
is that triangle thing supposed to spin off? I dont know how else to get it apart and put more line on it.
Its stuck tight
SimonHS
11:53 PM
Yorkshire, England
Fleethirte
7:53 PM
Virginia
clock wise might help lol
Thank you. Got the trimmer from my neighbor. Needed a carb and fuel lines. Now it runs great. Even got a updated carb with a purge bulb.
Partner
12:53 AM
Poland
I also have this in my little Kawasaki, only this knob has the shape of a two-bladed propeller 😎👍 The paradox is that this spool brakes the engine in contact with the ground, and it is used in small engines, so you should mow higher.
STOVE
7:53 PM
Eastern NC
I’ve had luck as others said soaking my line. I also cannot speak highly enough of the max power twisted line. It’s super durable.
I didn’t have much luck using the gray husqvarna line, or the echo red color one.
