Trees you've cut
BlackCoffin
11:07 PM
Washington
Guy I know had the back half of his massive oak tree break off in a storm last fall. Told him I’d like the lower limbs and base for milling. Took advantage of the nice day to get it all taken down. Was up in the crotch cutting the limbs and had a chain to the excavator wrapped as high as we could get them to pick them down after they were cut. Finished up with the 880 on the stump. Should make some decent slabs when done. Would have gotten more cutting videos but I’d was a slam it out and I went back to work kind of project.
davidwyby
11:07 PM
Extreme Southeast CA
Seems bout everything get hardened by the climate here once it dies. The ash and euc I just cut were both knocked down at the same time, the euc might have had more moisture, it was heavy! But it’s also very dense and heavy even when dry.
Dry Ash is hard, but Shag Bark Hickory has it beat!
That said, everything cuts better when it is wet ... lubricates the cutters!
Maintenance Chief
2:07 AM
South Carolina
Mesquite is hard, dry or not. View attachment 328954
That arid climate just like a very cold climate would definitely tighten up the growth rings in your trees.
I'm pretty spoiled in South Carolina with its mostly tropical summer and wide variety of trees , cutting can be very diverse from day to day .
Timjus
9:07 AM
Finland
picture.php
Scotty Overkill
Serial Tree Killer
2:07 AM
central PA
Well spent an hour or so the past several evenings and milled that big maple log up, hoping for some curl.....but there really wasn't much in it. Beautiful wood, nonetheless. Tight grained, too. Made for some nice live edge.
That stuff is HARD and sure dulls the chain quick. I was getting 3 passes or so before the chain started getting slow. Hitting an eyebolt and some nails didn't help matters, either....lol
Scotty Overkill
Serial Tree Killer
2:07 AM
central PA
Pic of one of the 9' slabs leaning against the back of my "EFF TOO FIDDY", they are around 24" wide, 1.25" thich and weigh around 100lbs each, give er take....
Got em all leaning up in the garage, gonna sticker them sometime this weekend.....
2:07 AM
Milling is tough on chains and saws ... all that fine dust.
I usually set up two 660s with 36" full comp square file.
Say I'm milling 22" Red Oak at 7.5' length, I'll fill the tank after two cuts and change saws after 4 cuts (if I don't hit anything).
By then I'm usually spent and take the stuff home and sharpen it.
A lot of work, but I love how the boards come out and what I make with them. I usually keep the half round sides for benches.
This is at my cabin. The bench on the left is Chestnut Oak, the table is Chestnut Oak and Red Oak (the center piece and legs), and the bench on the right is Hickory.
