With a barkbox you dont even have to cut the small ones. They fall over in shear terrorNice
I think when u drill holes in the muffler instead of the bark box. The tress would fall in the other direction?
Why the tall stump?
ENGRISH PREASE !?!?!?!?It's a "Schoolmarm". If the stems on a schoolmarm as a set of doubles are out of lead, then you fall them the way Mr. C did in his pictures.
If it's in lead to fall them as a set of doubles broadside, then you can do that. You have to make sure the union is strong enough for that though.
You basically have 2 trees growing up from 1 trunk ,some refer to them a codominates . You can fell each lead trunk independently or down low from the side of the two trunks if they are conjoined as one down low.ENGRISH PREASE !?!?!?!?
Hypersaws has this ??
