Trees you've cut
BlackCoffin
5:43 PM
Washington
Put an old wild cherry down today. Came across it the other week and figured I needed it. 22” on the base. Got two 10 foot logs to mill then 5 logs for bbq firewood. About 53 year old tree. Was only down the road so took the forklift for a cruise to grab it. D458A799-FC8E-408C-B288-7E8D308A526A.jpegA0EB880F-9BC2-464A-A713-8B18BFA494F1.jpeg 737F8F86-2F31-4DE5-8B3F-CE8643A1E026.png
Wolverine
dilligaf
8:43 PM
Took down this walnut Sunday, 24” on the butt end.
Very nice with little sap wood!
jacob j.
Only the weird
5:43 PM
Coastal Oregon
Why the tall stump?
It's a "Schoolmarm". If the stems on a schoolmarm as a set of doubles are out of lead, then you fall them the way Mr. C did in his pictures.
If it's in lead to fall them as a set of doubles broadside, then you can do that. You have to make sure the union is strong enough for that though.
Moparmyway
Its just a saw
8:43 PM
In a meeting
ENGRISH PREASE !?!?!?!?
Maintenance Chief
8:43 PM
South Carolina
You basically have 2 trees growing up from 1 trunk ,some refer to them a codominates . You can fell each lead trunk independently or down low from the side of the two trunks if they are conjoined as one down low.
HYPERSAWS
West coast cutter
5:43 PM
I could have fell them together if the lead was sideways, but the lead was straight up or straight down and I was fairly confident things would have went haywire if I tried to fall them together straight up or straight down, so spring board time
Hinerman
7:43 PM
NE OK
I knew there was a good reason…
LOL, I don’t speak badass logger either…
Hypersaws has this ??
I have absolutely NO doubt that he does!!!!
