Trees you've cut
BonScott46
9:42 PM
Sweden
Certainly lots of wedging. It’s the unburned understory that’s horrible. Nothing bends like it should, everything is sharp, it looks like an anti logger designed the perfect logger traps to maim and kill
Where is the unburned understory?
chiselbit
12:42 PM
Norcal
All those partially burned Alder and madrone and cedar saplings sticking up in the picture. The branches burned down to Fire hardened points, very sharp and flesh hungry. And a small madrone or Alder that would ordinarily just bend to the ground and snap when you drop a small tree on it will now act like a damn catapult and launch stuff in unpredictable ways. Smaller brush burned down to hard, sharp punji stakes all over the ground perfect to trip and impale. Just have to move around in it carefully. I would imagine before the fire a guy wouldn’t have been able to walk through there without cutting paths, was probably solid brush.
Hinerman
2:42 PM
NE OK
Wow. So neat and orderly. Nice
No kidding. I like those baskets but 1) they are expensive, 2) I don't have anyway to move 'em, 3) unloading them would be a PITA; but, they do make for a neat and orderly stacking area. I would also be concerned about the baskets in the middle seasoning at the same rate as the outside baskets
Flying_Dutchman
3:42 PM
MI
Black oak, probably about 3.5 feet across. The only solid wood was that lighter colored rim around the outside maybe an inch thick in the thicker spots. And a really weird looking mushroom or something in the hollow spot. Looks kinda like an octopus. [emoji1787]
Sent from my moto g(7) power using Tapatalk
Cedarkerf
12:42 PM
Washington
First 2 pics a tall heavy side leaner with a house and large shop shop with in range thus the thick hinge. Worked with an excavator guy to clear a fence line of scrub pines and a small pile of Doug fir logs a good day for sure. More I use the 500 the more I like it and I loved it from the beginning. To get a significantly lighter saw you have to go down to 50cc and a major power drop off. Weighs just a bit more than the 362.
20210410_141215.jpg 20210410_141041.jpg 20210410_114812.jpg 20210410_110123.jpg 20210410_141732.jpg
fearofpavement
3:42 PM
Georgia
Tornado cleanup in Newnan, Georgia. This town was hit very badly a couple weeks ago. They're still hanging wires and there's debris all over. This pic is of a blowdown water oak adjacent to a damaged house. They have about 50 trees down just on this property. Roof metal is wrapped around trees 50' feet up and all sorts of fascinating tornado damage phenomena.
On this part of the tree I am using an MS660, 36" bar and 3/8" skip tooth chain. Other saws used were Groundi's MS180, my 026, 046 and the Chinese eBay saw that I have an ongoing review on. (I'll have to update that I guess)Bucking blowdown.jpg
fearofpavement
3:42 PM
Georgia
What used to be their barn and storage shed. It's tricky cutting up the tree wood when it's mixed with shingles, metal roofing, broken studs and other debris. Nails sticking up all over the place and plenty of other hazards to deal with. This wasn't a little yard barn but a garage sized building with additions.IMG_1662.JPG
