- 6:48 AM
- Feb 5, 2016
- grafton wv
one is for spark the other is for the mtronic carb one side is north south the other is south north
Okay so the ignition side builds up a charge in the coil as it passes the poles and releases it to the plug. How do the poles for the solenoid work? What happens to this charge for the solenoid if its disconnected?one is for spark the other is for the mtronic carb one side is north south the other is south north
golf is a pussy sport
lol only golf balls ive hit was with a ball batI didn't know you played
Won't work without the circuit complete.Okay so the ignition side builds up a charge in the coil as it passes the poles and releases it to the plug. How do the poles for the solenoid work? What happens to this charge for the solenoid if its disconnected?
Why 2 sets of poles?
Chip and Dale?
Nothing wrong with central Illinois water!starting to think there is something in that IL water you and ted drink
You either need the euro coil or do some fancy wiring in the harness to get rid of the solenoid
Or Flint Michigan they tried to tell everyone...Nothing wrong with central Illinois water!
I couldn't say one way or the other honestly.Can we agree the euro coil is limited? Or all of this is for naught.
Are you a water operator?Nothing wrong with central Illinois water!
Just run a hotrodded 288 n prbly blow da doors off da 661.I guess the bottomline is if I got a 661 and ported it The Monkey business would be required !!!![]()
