wigglesworth
Knocker of midget farts......
- 4:18 AM
- Jan 10, 2016
- In a van, down by the river...
Most limited saws don't gain unlimited but maybe these do.
Huh?
If a saw is limited to say 13.5 but turns 10.5 in the wood how can tuning it faster gain?Huh?
Me tooi was thinking more of retarding the timing to fool the advance curve
That's the $50000.00 question isn't itIf a WJ69 will run a 064/066 out to 15000 why wont it on a 661?
Guess it will depend on the saw being a cant or work saw?I think somebody just done a thread testing coils and carbs.
Seems like the carb and mtronic were basically even and if leaning one out is a gain then it would be a gain whether it's limited or not.
LMFAO$64,000 question.
So you Are in your chair pissing yourself laughing at us then Scottit's a high fly ball going out to right field, and you all are running out to left field. it's hard to catch the ball when your nowhere close to it.
That's right.Guess it will depend on the saw being a cant or work saw?
So you Are in your chair pissing yourself laughing at us then Scott![]()
Are you going to put us out of our misery at some pointwell, yes. it was not the intent of this thread but it is good entertainment
It appears to me the answer has been given, just didn't sink in for *s-word........
Damn.....well let me try to explain this in another way.
so, sir major *f-wordwad wants to make a porting change. he stops at the shop and videos 2 test cuts to set a baseline for the day. brings the saw to my place. we tear the saw down and make the change. put the saw together. go back to the shop and video 2 test cuts. we get 3tenth faster cut. go back to my place. ter the saw down make a slight change. put the saw together. back to the shop. video 2 test cuts. we get 2 seconds slower times. decide to try the wj69 carb again. take the mtronic carb off. remove the solenoid from the carb. plug it into the wiring harness. put the wj69 on the saw tuck the solenoid and wiring in the carb box. fight with the choke to get the saw started. tune saw. video 2 test cuts. cut time is slower. then mtronic. attach tach to saw. runs around 13.000 or so. tune saw with tach. make video of tach reading, 14,480. tune saw to 13,8oo. video 2 test cuts. cut around the same time as mtroic. done for the day. post video of tach reading. all hell breaks loose on the nets. and here we are.
