Todays handy tip
P.M.P.
Stiff Member
1:14 AM
Michigan
Don't have pics but got a use for old tires for ya. I Use the tread under wood stacks works great keeps them off the ground .To remove iffin there still on the rim just take a razor knife cut around inside wall just below the tread.Then take a sawzall metal blade cut through the tread.
P.M.P.
Stiff Member
1:14 AM
Michigan
Hey got a 346 well you should :cbiggrin:change the clutch cover and put a 455/460 the chain adjustment is superior. Just got to remove the adjusting pin. Also if your going to run a outer dog you will have to do some grinding on the face so it will run to straight no big deal.
12:14 AM
I like this idea.
12:14 AM
@Jon1212 ; SAW ABUSE! Report, report!!! If you can't fix a mini mac, send it to someone who can. Saws are a terrible thing to waste. I fix 'em, they're really not that bad once you figure them out.
KenJax Tree
¯\_(ツ)_/¯
1:14 AM
Over there
If you have enough tires you don't even need the wood.
Jon1212
Birch! Please.....
11:14 PM
Utah, unfortunately.....
Careful what you wish for........
Fastenal shipping an entire crate of MiniMac's isn't out of the question.
P.M.P.
Stiff Member
1:14 AM
Michigan
We use inverted plastic Bedliners out of pickups to go on top of the wood stacks. Stack the closed end higher and rain and snow melt runs off
Sent from my XT1585 using Tapatalk
They also work great for leaf pickup just tie a rope to each front corner for pulling and rakem in. I use to use a tarp now its a bedliner
