Tips for making fish-gill slits in a muffler? IE how to make them "flare out"?
Cerberus
Cerberus the aardvark, not the hell-hound!!
1:51 AM
Florida (tampa area)
I don't want to make them on my "important" muffler til I get them down and I'm trying on thinner mufflers w/o much success at anything but hack-job work....I just don't "get it" how to make a proper fish-gill or louver, it's as-if you need to stretch the metal (which of course does not stretch, lol :P )
Would also be curious to hear people's thoughts on the more "meta" subject of placement of gills (or of muffler-exits in general), for instance I'm placing some gills on the top/front half of a muffler that's got an internal baffle plate, the OEM design has zero exits in the rear-half of the muff and neither will my finished product, at any rate for placement of my slits/gills I'm planning to:
- keep them higher on the muffler, like near or on the top of it (because fuel sinks downwards, so would think that higher=better and lower=worse, generally speaking)
- put them dead-center because my baffle prevents a "direct path" from the exhaust-port, to the front-portion of the muffler. This way I keep the 'factory concept' of that first muffler-half being a sealed "extension of the cylinder" before gas escapes-into the front portion where it can exit the muffler (I did significantly enlarge the baffle's passages in this case!)
Thanks a ton for any insight, have tried on a couple throwaway mufflers and hate my results, will not share them LOL they are horrible, cannot get myself to do it on my actual project-saw!!
ammoaddict
1:51 AM
Granite Falls, NC
I've never done it but I saw a video of someone cutting the slot with a Dremel cutting wheel and driving a cold chisel in it and prying it open. Have you tried googling it?
Sent from my moto g(7) power using Tapatalk
USMC615
Fapper Fi
1:51 AM
Mid-Georgia
This will work.
Maintenance Chief
1:51 AM
South Carolina
I cut a slit with a dremel wheel. I then use a small anvil or heavy chunk of iron and take my 10 oz ball peen hammer and stretch the metal from the inside first.
Since the slit is a open end it will buckle up when the metal stretches and flair up.
After I've created a hump in the area behind the slit I shape it with a square piece of steel or anything really , striking it with the hammer. 16327013802142026686505450444141.jpg
Craftsman 3400 side view.
Just do a lot of little forceful hits with the hammer don't try and get it all in a few smacks.
cash192t
New OPE Member
12:51 AM
arkansas
I have a pair of vise grips, think hvac or sheet metal pliers that are made for bending metal. While I havnt done a muffler I have done just about anything but that lol. they are cheap enough you could buy a pair, cut the pliers head to the width you need. may have to taper them with a grinder after. after you cut your slit with dremel, grinder, whatever. insert pliers, lock on and bend. gives straight even bend. on thicker stuff I heat the ends so they bend without tearing.
