RIDE-RED 350r
- 11:53 PM
- Feb 8, 2016
- Blossvale NY
Wish I could give you an answer but I've never ran a 44 and have to get my 242 back together
44 was said to be a semi as you say ...444 was said to be the pro version .I kinda figured the 44 was a semi pro saw. Much better quality than the farm & ranch saws husky sells today
44 share bearings & seals, piston ring, and one gasket with the 242 class, and thats about it.My first saw was a Husqvarna 44 I still have it. It is quite a little powerhouse for what it was. I'm not to familiar with the 242 other than knowing it was an XP pro saw. Are there any similarities in the two?
Thanks Tor44 share bearings & seals, piston ring, and one gasket with the 242 class, and thats about it.
Muffler is the same as they used on 133/234/238.
Them 44's is good saws, alot NLA parts though, they are more or less forgotten saws, freebies or max 20$ project saws from the dealers, can't go wrong with them.
yes, 242 is far snappier through the whole rpm register, the power head is better shaped too.Was the 242 quite a bit snappier? I never had the opportunity to run one.
Those things are so old they needs a diaper and a walking frame !!Hooray 242!![]()
I do a decent amount of field line trimming all through the yr and mostly walk to where i'm going to cut. The pic is typical of the timber i'm dealing with (15 inch ish at the butt) .Some of what makes this thread so interesting is guys aren't just talkling about what they do TO a saw, but what they do WITH a saw. Most of us have quite a few to pick from, so it's good to hear which saws guys like to grab for different tasks. And how some gravitate from one to another.
We're all power junkies, so in the same way we try to get more power out of a saw, we often probably grab more saw than we need for a particular job. But, that's part of the fun in my book. At least once a year, Walt and I drag out the Jonny 920/930's. It's a favorite chassis and we just enjoy running them.
I almost always include a 372/2171 or 272/670 build of some kind when I go cutting. They will handle just about about anything I run into, and it's rare that I encounter something that really calls for a 90cc class saw like a 930 or 288. It's more likely that I'll use a smaller saw when breaking down tops or cutting logs 12" and under.
