The Wretched Wrench
XP_Slinger
They’re Just Saws
2:02 AM
Central NY
Sorry about your frustrating day. But I gotta say, your grammatical illustrations of the events that transpired were an incredibly entertaining read. I felt like I was reading something that Mike Rowe authored. Ha ha ha! Well done!
Definitive Dave
Piss Rev Mafia Member
2:02 AM
Central Ohio
mmm..... kardashians without pantys!!!.what else did you say?:D
Bruce Kaitlyn says hi :)
oh crap that might be politically incorrect, I apologize but as the brilliant Artie Lange says " the greatest athlete of our generation decided to cut off his d1ck, can I maybe have a few minutes to get used to the idea?"
Peace and bacon but no snackies
Dave
Jughead
2:02 AM
Dave
Not that kardashian.I'm offended Dave.:risas3:
Definitive Dave
2:02 AM
Central Ohio
the Stihl block off manifold that comes with the pressure vacuum kit, it has a plug that is integral for blocking the impulse line, you can almost see it hanging out of the carb box in the first pic
sefh3
2:02 AM
MI GO BLUE!!!!
Oh you have those fancy tools. How is your boot?
Definitive Dave
2:02 AM
Central Ohio
I am a total fancy tool nerd :)
Boot is new but I will spray it with bubbles just in case.
Of course I have to redo the clutch side seal after blowing it across the room with the metal spacer :(
sefh3
2:02 AM
MI GO BLUE!!!!
I know this is a pain but I'm old school. I block the muffler with a tire tube and reinstall to make the seal. I then use another tube to block the carb. I insert the Mighty Vac on the impulse line. This will assure the line is good. I'm seen brand new impulse lines leak.
Basher
3:02 AM
Canada
Just a couple weeks back I pulled a big, Duuuh! I use my Mity Vac almost daily and have so for many years. Pulled out a saw I just rebuilt and ported, was ready to ship it off, box and stuffing at the ready. Thought I would give it its last go over, clean it up as I had test run it and tuned it. Put in the blockers and test plug and hooked up the vac tool, sum of a beech, wouldn`t hold vac, try pressure and nope wouldn`t hold. What the fark! .started pulling the saw apart, squirting suds all about, pulled the flywheel, clutch and no bubbles anywhere. Stopped,had a coffee and had a light bulb idea from out of right field. I blocked the end of my test hose with my thumb, tried vac, nope won`t hold, pressure neither, dip the hose in the liquid and there were the bubbles!!!!
Deets066
AKA Deetsey
2:02 AM
I gotta ask what the JB weld is for?
I know as much about machining as I know about arthroscopic surgery, which is to say....nada
Yours is on the right Dave, when I turn down the raised area around where the stack will be it is hollow. I found this out on mine, which I need to JB weld and turn it down a little farther. Gives the filter a little more room to clamp on.
jmssaws
Banneded
1:02 AM
I didn't like v stacks because of the open carb,but now....
