old_sir_henry
- 11:14 PM
- Nov 9, 2018
The chain brake is in the side cover. Am I right in thinking these are based off the 100S?Interesting find! That's yet another sibling in this family of saws. Does it have the sprocket cover without built-in chain-brake (67)
like the DE3435?
The chain brake of the 100S is different. This one is like PS-340, PS-400 et al.The chain brake is in the side cover. Am I right in thinking these are based off the 100S?
This may be a really dumb question / idea but,
Has anyone run a 325 setup on one of these small 340/341 type saws? It have found a cheap 13" GB bar in this mount but I'm not sure it's going to pull it. Runs the 3/8LP really well but a 325 7 will probably be too much I'm guessing
Interesting, according to the lists I have the "DE" models don't have a chain brake, but maybe there have been different configurations for different markets.
I might try it but I'm not really sure what to do with this thing. It feels like so much more saw than a ms170/180 when using itI've never tried it on one under 35cc, but often saws between 35-40 cc had 3/8 LP and .325 versions, and it worked pretty well for both.
Probably your best chance of being happy with the cutting speed would be to use the .325 LP, which is what Oregon promotes for this size of saws. Of course, the edge retention might not necessarily be very good.
But you're probably only concerned with the .325 standard. If that guide bar is .050, then probably Stihl's Pro chains are a good choice to test (video?).
I wouldn't worry about the fact that the .325 sprocket is 7T. That's only about 3% difference (speed/force) between it and a 6T 3/8 LP (7*.325 / 6*.367).
Well, maybe because it is not a clamshell design? Of course, formally the peak parameters usually quoted by manufacturers (vs. MS 180) are not significantly different. But, as we know, these parameters do not necessarily translate into impressions of practical use.I might try it but I'm not really sure what to do with this thing. It feels like so much more saw than a ms170/180 when using it
Probably not. I think I will just leave it with the 3/8LP and have some fun with the saw.Other than a cheap bar being available, is there any advantage to .325? I have always found that a good quality 3/8 LP chain is about as good as it gets on a sub-50cc saw, and there are numerous options. My favorite is the Oregon PXL but there are many other good ones out there. Gonna try Husky X-Cut next, I absolutely love it in .325 on my 50cc saws.
