heimannm
12:13 AM
Dike, Iowa
Blue to purple is 540-590° F, clutches get that hot too often...
Other have suggested running as it is (missing one liner) and/or removing the other two liners. For the short term he will use the 009 clutch as I explore other options.
Mark
Powerstroke Cowboy
11:13 PM
Montana
Mark
I stand corrected then. Thanks Mark
FergusonTO35
1:13 AM
Boonesborough, KY
Chris B sent me a link for some brake shoe adhesive that he has used, but at $26 for the kit we will pursue other options first.
Mark
That's really not a bad price if you get several uses out of it, especially fixing things no longer produced. I once balked at paying $40.00 for the two part tube of Devcon DA290 plastic welder but then discovered I have many uses for it.
lehman live edge slab
Live Action
12:13 AM
Mn
11.9 mm wide and 64.2 mm diameter roughly. Did yours have the flat cover with nut and washer on it. Supposedly the 020av and 015 used the same clutch but I haven’t found a part number on it. May need to dig in my books later. Even brake cleaned the bar oil off the asbestos liners 😂
heimannm
12:13 AM
Dike, Iowa
MS310 with very low compression. I measured the piston (1.847") and the bore (1.849/1.850") and the rings look good with plenty of spring.
Any idea why the compression would be so low?
Mark
Live Action
12:13 AM
Mn
Mark
What was the reading? Some of these saws had pretty loose squish bands and they can be even worse with aftermarket top ends.
FergusonTO35
1:13 AM
Boonesborough, KY
The 024/026/MS260 are my favorite Stihl saws of all. Love the design, I think the later ones were a step backward even if they are stronger. I think the success of the old as Methuselah MS250 is due the fact that it is essentially a plastic 024.
Live Action
12:13 AM
Mn
From what I understand they have better stock port timing. However, the seller states this one looks to have a new jug on it.
The red leaver means absolutely nothing and is a myth, Stihl molds their own plastics and it probably saved money at the time on red vs black or just did because. My all original from
1991 red lever 026 isn’t any stronger than some of the newer ones with black switch. Some cylinders may be better than others depending on brand mahle vs ks but the multi function lever has no indication to it. The myth started and perpetrated as a reason to charge more because people think they’re better.
Live Action
12:13 AM
Mn
The 025/250 was a strong seller because it was pushed like the 029/290 and was a durable saw for what it was. Not sure what saw would have more power the 024 or 025/250, even though it’s only 42cc vs 45cc I’m guessing the 024 will still win by a little.
They call me Mr. Kibbs
1:13 AM
Wandering the VA woods
I tried searching the forum, and feel sure someone has a solution but couldn't find one.
Ms180C, standard recoil, has some years on it. Loaned it to father-in-law, and apparently he had some trouble with the master control lever. Long story short, the outboard plastic boss (clip? )that holds the end of the plastic MCL, at the shut-off contact, broke. All works OK until you try to use the shut-off, then the MCL rolls up out of the boss and cannot make contact for shut-off. Can stop the saw with choke, but wondering if there is a fix other than buying the fuel tank/case half and rebuilding the saw?
hacskaroly
2100 Fanclub Member
10:13 PM
Northern Idaho, Ehh
For the price I figure it would be worth rebuilding without having to jimmy-rig it...IMHO
