bigbadbob
- 4:19 AM
- Jan 9, 2016
- Interior BC Canada
Ya think it will go up that much??? like 30-40psi?? Already a good hard tank thru it.The rings aren't seated yet .Flog it like a rented mule,it will come around
Already plugged and checked.Decomp may be leaking. Replace it with a bolt/plug and see if that makes any difference.
It has already been ground on by someone obviously.Ya think it will go up that much??? like 30-40psi?? Already a good hard tank thru it.
Can’t speak for an 066, but .004 –.005 is about the limit for clearance on a 395 before the piston starts to rattle. If it’s not rattling at an idle, it’s unlikely that is your issue.So i got 4 thou between jug and slug 5 thou wont go.
Slug measures from skirt up,, four places 53.92 54 54 53.85
Im assuming all is good??
guess i gotta find a jug.
thanks,,,,Can’t speak for an 066, but .004 –.005 is about the limit for clearance on a 395 before the piston starts to rattle. If it’s not rattling at an idle, it’s unlikely that is your issue.
The cylinder looks like it was “ported“ by someone without proper tools. It’s got no machine work done to it and it looks like the exhaust is raised way up which is bleeding off your compression. And I know for a fact that the Mickey Mouse ears in the top of the intake on an 066 cylinder are going backwards. It will run better with the roof 5° lower than stock rather than being opened up higher. All the ears do is slow down the incoming charge and direct it to nowhere.
Exhaust is too high.So new cabers,, ran a tank thru,, still not up to snuff,, comp was about 130 again WTF
squish 22-28 ,, 10thou BG Looks like somebody ground on the jug,,,,
This.It has already been ground on by someone obviously.
They could have raised the exhaust port so high that its breaking the seal with very little blow down.
And all this.Can’t speak for an 066, but .004 –.005 is about the limit for clearance on a 395 before the piston starts to rattle. If it’s not rattling at an idle, it’s unlikely that is your issue.
Thanks you sir...Exhaust is too high.
This.
And all this.
If the plating is good, I'd be willing to cut the base and squish for you.....but I doubt it would be a great performer even with more compression. Getting the exhaust as low as possible is my objective on the 066. The intake is a problem as well. I'd hang onto it as a "what not to do" conversation piece.Thanks you sir...
Thanks all of you,, yer the best.
Found a oem jug and its on its way.
Will check in later.
There were a couple of guys local to me that were setting up their intake ports like that (I call it the Mickey Mouse style).
