POULAN The Official Poulan Thread
5:55 AM
A Poulan S-25 weights about the same as a Stihl 020AV top handle and they both cut at nearly the same speed .The Poulan was the first saw I ever bought ,new in the early 70's and it still runs fine .It doesn't get much run time these days because I have a pair of Stihl 200 Ts ,one has been "enhanced ".BTW I also have a Stihl 020AV the most frustrating saw to work on ever made .
lehman live edge slab
Live Action
4:55 AM
Mn
I may be a little sick but I don’t mind the 020av or 020 avp to work on but can’t stand a mini mac
5:55 AM
This"turtle shell" design was a popular way to build certain earlier small saws and in some form more modern saws .One that sticks out are the small Husqarna top handles .If memory serves 235 maybe ? You just about need to field strip those things to do anything on them .I've got a couple of them with failed oilers .The trimmers gave them to me . .Reason they bought them was becausse they were less expensive than a Stihl 020T .They ran fine they just wouldn't oil .I've got a box full of them I may or likely not ever repair them .For that matter I might never find the box again .
FergusonTO35
5:55 AM
Boonesborough, KY
With Mini Mac saws you get a lot of practice...on every saw.
Back in the 2010's I had a whole fleet of Mini Macs because I hate myself. Seriously though, I didn't find them hard to work on or keep going so much as they are time consuming to work on. The case has to come apart to do anything but the most basic maintenance items. On the plus side, they didn't strike me as cheaply made, even the Eager Beaver versions. Also, when you buy a Mini Mac even as a non-runner it probably doesn't have much actual use on it. Most parts including the housing were metal and the fuel tank and other plastic bits were pretty robust. They gave me good service and most of them ran when I sold them.
5:55 AM
Since the conversation of Mini Macs came up I also have a box full of them and maybe another 3 or 4 intact ,all freebies .The oilers were the weak link .Once used by the trimmers who might get lucky and get two years out of them then buy another one .One or two of those things had such short run time they had the original chains ,never filed .Bought to trim the apple tree then sat for 5 months and then wouldn't oil .The little Homelites did about the same xl2 etc .All that goes back nearly 50 years and then the Poulans and the Stihl were the best on the market.
Clarkbug
5:55 AM
Northeast
Hey all.
I picked up a Poulan Pro PP295 at a flea market for a few dollars. It appears to have lived under an oily sawdust pile for the past several years. First time delving into anything on the yellow side. I have to say the cable throttle linkage was a bit of a pain to deal with....
Fuel line broke at the tank and the air filter was nasty, so figure that's why it was put away. But, I checked compression and it's low 100's. I tried to pull the muffler, but it's not coming loose. From the IPLs I can find it looks like I have a type 1 or 2 (tag is missing), so just two bolts on the outside of it, and I am guessing one is inside.
Questions for you guys: Is that compression too low to bother with? Any tips for separating the muffler halfs so I can get a gander at the piston? Looking through the plug hole it doesn't look like scoring on the exhaust side of the jug...
Thanks!
fossil
5:55 AM
Ontario, Canada
Squirt some mix in the spark pug hole and see if it will start.
That will get some lube in there. Some saws sitting for a long time might have a dry cylinder or stuck rings.
As far as the muffler bolts go, use some heat on the bolts.
A peppy saw for what they are.
Clarkbug
5:55 AM
Northeast
Thanks for the ideas!
Wanted to clarify I can get the two external bolts out, but I think there is one more inside the can I cannot get to. I'll have to see if I can heat up the seam to get it to pop open for me.
EDIT: It runs for a second with fuel poured down the plug hole, so that's something. Guess it's worth trying to fix it up....
Secondary question. Does anyone know off hand the o-ring sizes for the fuel and oil caps? I'm pretty sure these ones are shot. I can measure, but didn't know if it was a common knowledge sorta thing with these saws...
fossil
5:55 AM
Ontario, Canada
The proper "O" rings for the fuel and oil caps measure 1/8" thick with an ID of 1-1/16" . Make sure they are nitrile (BUNA N)
To split the muffler take a small slot screw driver with a sharp tip and pry it open. You can tap the flange back into place before you assemble it.
Clarkbug
5:55 AM
Northeast
Much thanks! Ill snag some o rings and will try that trick to separate the halves.
I don't have the tool that fits the clutch, but would an adjustable pin wrench for an angle grinder work? Or I can try to find some pins or bolts that will fit and find a way to hold them at the right spacing. I tried using some plates from a brake caliper tools set that I have, but none of them lined up appropriately.
Bill G
4:55 AM
There are several people looking for Poulan 4000 top ends. I am wondering if there are any other models that will fit the 4000. I have several 4200 and 4400 saws here but of course they are larger.
fossil
5:55 AM
Ontario, Canada
I made a few sockets that work well on clutches. Take an old or cheap socket and cut down on them with a hack saw and break the piesces out af the socket to leave two opossing tabs. Works well.clutch_sockets[1].jpg
Clarkbug
5:55 AM
Northeast
Well, I managed to find enough time to get the PP295 put back together. Carb needed a cleaning (sawdust in the screen), a kit for stiff diaphragms, new AF and new fuel lines. What a pain these are to reassemble! (I am mostly used to Echo/Sthil stuff) Anyway, it was popping off with a squirt of mix down the carb, and ended up running after the H/L screws were turned out maybe 3.5 turns each. Probably the most out I have ever had on a carb. Not sure if that's just the nature of this saw, or if it means I am trying to chase a leak I don't know about.
Managed to get it to idle down and stay running for several minutes. Need to have some more time to try and tune it a little in some wood and see how it does. I will say it seems like it oils like no tomorrow. There was a mess all over everything after I turned it off. Also not sure if its because I didn't cut any wood, so all the oil just kinda pooled and ran around the bar, or if Im actually leaking a lot of it out at the oiler port.
Appreciate the help so far, and any other tips for getting this one dialed in. I have some old beams I am planning to use this bar/chain on, and then planning to put an adjuster on it and get an 18" or 16" setup for it, keep it on hand as my backup/loaner saw.
B Royals
5:55 AM
Indiana
I bought this saw from an online estate auction this week, site unseen. I picked it up yesterday, and the previous owners' Son was there. His Dad bought it brand new in the early 80's. One owner CV5400. I'm going to tear it down and clean it before I try to start it, but I think it's going to be a good one.
Bill G
4:55 AM
I have sold/traded a,lot of 5200/5400 saws. They are nice finds.
B Royals
5:55 AM
Indiana
So I have noticed while searching on the forum, half of them are yours. lol There isn't a whole lot of information about the 5400 compared to other model saws. This is my first big Poulan, but they sound like they are a hoot to run. As far as I can tell the saw is complete, and I haven't noticed anything broken yet. fingers crossed.
