Llama
Active OPE Member
- 7:54 PM
- Jun 2, 2025
- In the garage
Hey guys first timer here with some experience and lots of research. I'm working on a 2003 Poulan 2375LE wild thing. Did a little porting on the exhaust and reduced the squish to about 0.022". Not sure if the LE stands for limited edition or low emissions. It's a non strato.
Anyways the cylinder looked good, most of the cross hatch marks were visible, I bought a new "husqavarna" ring as the old one was roughly 0.030" end gap. The new one is a little over 0.025" which was disappointing. Maybe normal? Maybe it's the cylinder, maybe it's the ring. Compression is only in the 135psi range at best. Compared to 120psi before.
I'm thinking instead of buying a new cylinder I can buy a 41.5mm ring and file it down to about 0.007" gap. I'd have to take off roughly .040" from the ends and the radius or curvature might not match the cylinder perfectly. I think it would be really close and just take a little longer to break in. Has anyone done this before?
