POULAN The Official Poulan Thread
Cut4fun
Redneck Chainsaw Repair
7:51 PM
Ohio
Think I got them all figured out but 1. Some of the ones I thought poulan, were pioneer x3 cylinders. P28, then WT coil, K650 partner cyl, P 3450 T1, P 2750 2775 295, PP114, gasket K650 700, Piston 336 3450 330, 2775 2750 295, P26-P28? and one I cant figure pioneer 475350 or 507475350
Hmmm forgot to write # down for 1. Got more in pic then wrote down. LOL
Cut4fun
7:51 PM
Ohio
Last one was a weird jred 370 clammy
ChipsFlyin
OPE Platinum Member
7:51 PM
Pittsburgh
Found this in an old AS post
"P26 piston #507475350, ( Jacks Small Engines ) NEW- $12.78+ shipping"
Edit:
The cylinder that goes with is # 507431400
Cut4fun
7:51 PM
Ohio
Only difference I noticed in the 2 Pio pistons. One of then had one side with narrower skirt. Both went into all 3 cylinders same fit it seemed.
ChipsFlyin
OPE Platinum Member
7:51 PM
Pittsburgh
The cylinder # that goes with is "507431400 fits model P21,P26,P28,1074 and others." IDK maybe it's like Poulan stuff -slight changes but works in/with many.
Cut4fun
7:51 PM
Ohio
All 3 cylinders that #
Cut4fun
7:51 PM
Ohio
I wish they would fix the search function here.
Any how info I dug up I saved in my file cabinet website. That nos piston 530069547 with the superseded number 530071321
The cylinder # that came back to type 1 3450. Thinking about it in my sleep it couldnt be. No impulse nipple and transfers different. Again I found info. Glad I left that place open just for saving the info to. http://chainsawrepair.createaforum.com/poulan/poulan-336-54cc-cylinder/
Fishnuts2
6:51 PM
SE MN
I was able to pick up a nice 4000 last week. Cleaned it up and put the edge back on the chain, and it cuts real well.
Thinking I should take my bow off my 3400 and put it on this saw instead.
Fishnuts2
6:51 PM
SE MN
You mean forget the bow?
J. Dirt
7:51 PM
WNY
What have I got here guys? Going to be my soon to start on project. It’s says Poulan pro, but a lot points to pioneer. I’m not up on my company history, but it looks like a cool saw.
6E23FB96-EAAB-4965-95B1-1B757E0A054B.jpeg 1EA93927-E2D9-4AAE-811C-1ECD39817DAD.jpeg 78194932-0EE9-4EE8-85F0-B4A7BC527600.jpeg DFF4D4C6-1767-4C39-8229-97D155863207.jpeg
S Sidwell
7:51 PM
Georgia
Get a 3400 and put a bow on it, save that 4000 in it nice pretty condition.
Once you cut the case and cover, you don't want to put a bar back on it. You will have to run the chain with less slack so the chain doesn't hit the lower brace. They make a different handle brace for bows but haven't see any for sale.
Steve on Tapatalk
S Sidwell
7:51 PM
Georgia
fossil
7:51 PM
Ontario, Canada
View attachment 229473 View attachment 229472 View attachment 229471 View attachment 229470
Very rare saw in North America. Quite a few I think in Australia. It's pretty much the same as the Poulan 655BP which is a very desirable saw.
Well worth restoring as you will have a very rare Pioneer Partner based saw saw. 98cc saw and very powerful.
The AF cover on the saw is not labelled as the correct one. It's not the Poulan variant by name only. It should be labelled as "Pioneer Partner"
Great score!
Fishnuts2
6:51 PM
SE MN
Steve on Tapatalk
I already have a 3400 with a bow on it. I was just thinking the 4000 would be a better choice for the bow. I didn’t have to cut the case for the bow, only had to modify a clutch cover, and I have quite a few of those on hand.
I made or modified the lower handle brace to fit the bow, but have since found a NOS brace for use with it.
I thought it would be a good combo, but I wouldn’t make any changes to the 4000 that could not be reversed. Took me too long to find it!
MolluskMania
OPE Member
6:51 PM
Ashland, WI
Wow, that’s pristine!
S Sidwell
7:51 PM
Georgia
You sure you don't have to cut the case for chain clearance.
Steve on Tapatalk
Fishnuts2
6:51 PM
SE MN
Steve on Tapatalk
I didn't change anything on the 3400 other than cutting the clutch cover away on the top for clearance, and cobbling up a lower handle brace. But I should tell you that I have not seen a genuine factory installed setup with a bow either. I might snap a few pictures this afternoon to have you take a look. I'm sure you and @acornhill know much more about these rigs than I do, so now I might just leave the 3400 with the bow. I only run it occasionally anyway.
S Sidwell
7:51 PM
Georgia
The last one I got looked factory to me, has original paint in the cut out in the case and cover.
