- 11:42 AM
- Jan 26, 2016
- South west UK
Put a couple 2x6's flat on ground up against vertical splitter base and makes moving those rounds or half rounds much easier. Also makes it so you do not need to tilt the round into splitter. Just a suggestion.View attachment 97871
Red Oak....Very Heavy Red Oak!!! This little Swisher 22-ton has been a sweet little machine for my wife and I to split our winters wood since we bought it new in 2008. I would say we have split near 400 ricks of wood with it. We cut and split about 50 ricks each year for our home and my parents home. Both we and my parents have outdoor wood furnaces and my Dad also heats his shop with wood. In the photo that's me working the ground and my Dad is running the tractor. This was about a 36" solid red oak that had blown down (uprooted). Once we got each block on the splitter and busted it in half, then I could wrestle each half by hand.
View attachment 97872 View attachment 97873
For reference my Dad (blue shirt) and I (green shirt) are both 6'-0" tall. I'm guessing the largest blocks weighed near 400 lbs each. After splitting them in half it was all I could do to scoot each half back up onto the splitter shoe for the next hit. The quarters were much easier to man handle. Nice thing is that the grain was straight enough for the 22-ton splitter to handle with no problem.
Good idea...nice Al!I did a little improvement on my splitter .This thing is so massively heavy it has became a real problem tipping it up and a bigger problem laying it back down .I had to use a cable come along to tip it back over .So a cheap boat winch,a couple of eye bolts ,3 feet of cable and a cast iron idler pulley saved the day .Works like a charm
Mels, no offense. But I think your still not on the same idea of what an auto cycle does. Your thinking of detent return. Where you holt the lever the entire extension stroke. But the lever will stay in the return stroke untill it bottom out s s the lever returned to nuteral.
This is an auto cycle valve
You move two levers at the same time and it will extend and retract without any operator input.
Mels, no offense. But I think your still not on the same idea of what an auto cycle does. Your thinking of detent return...
Ryan, they do sell slip on collars for hydraulic cylinders that limit the return stroke length.
I used them on our hay rake that would always settle out as I went across the field.
You put them on the rod shaft and it essentially turns your 36in long travel to as short as you want. Then your not auto cycling 12” that you never use anyways.
http://www.catford.com.au/images/prod_images/PHRAMS.pdf
They might even have them on the shelf of your local farm implement dealer/tractor supply.
