Lnk
Stock Chainsaws do not suck!
- 4:33 PM
- Oct 12, 2021
- East, TN
Just needs a plug....View attachment 380259Think I need a tube
I can relate, most of my flats look that way too.View attachment 380259Think I need a tube
Did that make a nice boom? Last time I had one do that, I about had a heart attack.View attachment 380259Think I need a tube
I wasn’t there when it let go. It was on a wagon pulling seed bean.Did that make a nice boom? Last time I had one do that, I about had a heart attack.
What was Lasso used for? I can’t find a lot of info on the web other than “anti herbicide” propaganda.So my friend called & wanted me to spray some trees & brush in his pastures. I get there & he doesn’t have enough dope for more than 1 tank & he tells that he thinks he has some at the other farm. So I start digging around & this is what I found. I just cracked up.
I told him I hadn’t seen a jug of Lasso in 40 years & it’s probably been 25-30 years since I have seen a jug of Banvel. Needless to say he needs to buy some more Pasture Guard & Grazon.
I am trying to get the Banvel ( dicamba) from him since it works well with Grazon for Eastern Red Cedars.
I’ve had good luck with CrossbowSo my friend called & wanted me to spray some trees & brush in his pastures. I get there & he doesn’t have enough dope for more than 1 tank & he tells that he thinks he has some at the other farm. So I start digging around & this is what I found. I just cracked up.
Mainly Grass & some broadleafs.What was Lasso used for? I can’t find a lot of info on the web other than “anti herbicide” propaganda.
I mixed up a tank with some Grazon & Crossbow today. I will see how it works. Rick is pretty set in in ways about doing stuff & doesn’t like changing things up.I’ve had good luck with Crossbow
If it’s a 13” wheel I’ll have the tyreAt worst a patch inside and a tube. It’ll finish the year out loli
Neighbor sprayed some multiflora rose in the fence rows with DuraCor and it seemed to do a good job with them. We are hitting thistles and nettle right now so I need to look into getting some as well so I can get some spraying done.I mixed up a tank with some Grazon & Crossbow today. I will see how it works. Rick is pretty set in in ways about doing stuff & doesn’t like changing things up.
I normally use 3pint of Pasture Guard, 2 pint of Grazon & 1 pint of crop oil per tank (25 gallons ) for multi flora rose, Osage, Honey Locust & other brushy stuffs for him.
Today was 3-1/2 pint of Grazon & 1-1/2 pint of Crossbow & 1 pint of crop oil.
He has another brew for thistles, I prefer a one pass method but he has his ways so I do as he wants. At $60 hr, I can make two trips. Lol.
@JimBear haven't seen Lasso for years I think the green lobby stopped it over about 25+yes agoSo my friend called & wanted me to spray some trees & brush in his pastures. I get there & he doesn’t have enough dope for more than 1 tank & he tells that he thinks he has some at the other farm. So I start digging around & this is what I found. I just cracked up.
Not good!Baler trouble fellas. I have a hesston 5540 from the 80s. I've done a lot to it over the last few years, and hate to give up on it. Parts are tough to get here though. Any of you guys know where any of these are that are being parted out? It makes a 4x6 bale. The upper roller was spinning on the bearing and ruined the end. I need a roller tube for it.
Got a pick of the roller? Probably can be fixed.Baler trouble fellas. I have a hesston 5540 from the 80s. I've done a lot to it over the last few years, and hate to give up on it. Parts are tough to get here though. Any of you guys know where any of these are that are being parted out? It makes a 4x6 bale. The upper roller was spinning on the bearing and ruined the end. I need a roller tube for it.
It would need a new end.Got a pick of the roller? Probably can be fixed.
If you can get a measurement.Baler trouble fellas. I have a hesston 5540 from the 80s. I've done a lot to it over the last few years, and hate to give up on it. Parts are tough to get here though. Any of you guys know where any of these are that are being parted out? It makes a 4x6 bale. The upper roller was spinning on the bearing and ruined the end. I need a roller tube for it.
Elvis is pretty slick. I’d call him Monday morning. He’s a parts guy not just someone that answers the phone. I’ve dealt with him a couple times. Kept his cardGood suggestion! I was going to mention them as well.If you can get a measurement.
I’d try all states ag. They have dismantled Heston stuff
View attachment 380309Elvis is pretty slick. I’d call him Monday morning. He’s a parts guy not just someone that answers the phone. I’ve dealt with him a couple times. Kept his card
I just got home with Doyle's Vermeer. I'll get this stuff baled then get some measurements. Thank you fellas.I’ll call around the junkyards I have numbers for here Randy and see what I can find
