The Official Farming Thread...
Sagebrush33
3:11 AM
Upstater
It's hard to kill them bastards
@dall yup it is.
Years back 2 buddies and I were on a roof job. Front of the house had a small dormer over the entry and the yellow jackets had nested inside. We couldn't work near the area. All 3 of us got stung before we even knew they were there. The next day we were prepared for battle. We brought a roofer torch and an LP tank. I stood on the scaffold with the torch while another guy banged on the dormer roof. I kept frying them as they flew out of the eve. They just kept coming and coming. Musta been hundreds.
legdelimber
3:11 AM
N.C.
Hit the yellow jackets about an hour or so before first sign of morning twilight.
Seems to be when they're least likely to move around.
I've gone to dose 'em a couple hours after sundown and had them fly onto my flashlight.
I always use a dim flashlight for working on them now.
2:11 AM
2:11 AM
Thanks Boss man, works good with the pressure at 21 lbs. @ 16 gallons /acre. = 1.0 qts. roundup. and 3 qts. 24d. Amine/acre.
What sprayer is that? I have a 55 gallon sprayer, but it just sprays off the center. No booms. I needed to rig up a boom on it.
amberg
3:11 AM
Va.
Mr. Randy. this is a small tank that I rigged up for the Gator. The booms do 15.5 feet. The tank is to small to do many acres. I will be upgrading the tank next year to a bigger one, but the new 28 foot booms cost way more than the sprayer! Plus You have to watch your amps. ( With this gator no more than 12 amp draw on the alternator. )
JimBear
2:11 AM
IA
The Gator earning it's keep today doing broadleaf and grass control in the wheat Dove fields today with the new GPS system. Can hold it at 3 mph easy on the flat land. View attachment 302076 View attachment 302075 View attachment 302074 View attachment 302071
I have a 25 gallon sprayer, that just has a 3’ boom but will cover around a 30’swath. A single center tip & adjustable angle tips on both ends, all three can be turned off/on individually. I mostly just spray thistles, terraces & fence lines with it.
https://www.fimcoindustries.com/spr...imco-25-gallon-atv-sprayer-3-nozzle-boomless/
amberg
3:11 AM
Va.
JimBear
2:11 AM
IA
Yes, each boom or center boom. Or each nozzle. Or center boom?
Yes, just twist a cap to turn them on/off, use them in any on/off configuration. there is a switch to turn the boom off so you can just use the wand. It works great to just use just one side for fences & terrace backs. I’m on my second year with it. I use ratchet straps to hold it in the back of the Gator.
JimBear
2:11 AM
IA
Here is a pic of the boom shutoff & pressure adjustment lever.
Here’s a pic of the on/off caps on the nozzles & the end nozzles swivel 360*, the center nozzle is not adjustable but can be shut off independently.
9FA4E5B4-9C0B-4615-AD38-952FD8175AF2.jpeg 3202A468-8889-4202-994F-9EB1267D46DA.jpeg
Hedgerow
2:11 AM
Seems keeping Kyle on feed an extra month made a difference.. I’ve not seen that much marbling in a filet in a while.
My favorite cut of the beefer.. tenderloin.. I always have them pulled whole and cut them myself.
Beef.....
It’s whats for dinner....
