beaglebriar
The Peanut Gallery
1:22 PM
Warren Center, PA
CrystalRiver1
12:22 PM
Alabama
Ye ole 064 fer $425!
PrevNext
Marketplace
Garden
STIHL 064 20inch bar
Robbins, TN · 2 days ago ·
$425 Seller Information
Jeff Lowe
Joined Facebook in 2013
Report
CrystalRiver1
12:22 PM
Alabama
PrevNext
Marketplace
Tools
Stihl MS361 Chainsaw
Henderson, KY · 54 minutes ago ·
$215
Stihl MS 361 Chainsaw Specs MS361 Engine STIHL single cylinder two-stroke engine Displacement: 3.6 cu.in (59 cm3) Bore: 1.85 in (47 mm) Stroke: 1.34 in (34 mm) Engine power to ISO 7293: 3.4 kW (4.6 bhp) at 9,500 rpm Idle speed: 2800 rpm Maximum permissible speed with bar and chain: 14000 rpm Clutch: Centrifugal clutch without linings Clutch engages at: 3,500 rpm Crankcase leakage test at gauge pressure: 0.5 bar under vacuum: 0.5 bar MS361 Fuel System All position diaphragm carburetor with integral fuel pump Carburetor leakage test at gauge pressure: 0.8 bar Operation of tank vent at gauge pressure: 0.3 bar Fuel tank capacity: 0.69 US pt (0.325 l) MS361 Ignition System Electronic magneto ignition (breakerless) Spark plug (suppressed): Bosch WSR 6 F, NGK BPMR 7 A Air gap between ignition module and fan wheel: 0.15…0.35 mm Electrode gap: 0.02 in. (0.5 mm) MS361 Chain lubrication Fully automatic, speed-controlled oil pump with rotary piston Oil tank capacity: 0.69 US pt (0.325 l) Oil delivery rate: 5.5 – 15 cm3 at 10,000 rpm MS361 Weight Dry, without bar and chain: 12.3 lbs (5.6 kg), with handle heating 12.8 lbs (5.8 kg) MS361 Cutting attachments STIHL reduced kickback bar (with green label) for 0.325″ and 3/8″ pitch: Rollomatic with sprocket nose 16, 18 or 20″ (40, 45 or 50 cm) STIHL low kickback chain (with green label) for .325″ (8.25 mm) pitch: Rapid-Micro 2 (23 RM2, 26 RM2) Chain Rapid-Micro C3 (23 RMC3, 26 RMC3) for 3/8″ (9.32 mm) pitch: Rapid-Micro 2 (33 RM2, 36 RM2) Rapid-Super C3 (33 RSC3, 36 RSC3) Chain sprocket: 9-tooth for .325″ pitch 7-tooth for 3/8″ pitch Less
Condition
Used - Good
Brand
Stihl
Seller Information
Scott Calipari Turner
Joined Facebook in 2007
Report
beaglebriar
The Peanut Gallery
1:22 PM
Warren Center, PA
Woodrow
Reynolds Crane - Home of Ported and Polished Saws
12:22 PM
Wisconsin
I emailed the guy on that 2152. We will see how he responds to the shipping question.
