1:02 AM
Meth use and addiction has sky rocketed in Canada in the last 12 months. As soon as the Govt announced weed was going to be legal the cartels really started pushing meth. Free samples for anyone, even laced the weed they were still selling to try and get people hooked on the meth high.
Our local Facebook Marketplace is loaded with people trying to sell stolen stuff to get that next high. Had someone offer me a New Makita cordless Impact kit for $100. Picture she sent me still had the store Anti-theft device still on it.
Sorry to hear this man. If you dont have cameras get some and dont leave your garage open anymore either.
dahmer
2:02 AM
Ellwood City, PA
Amazing how the progressives think that’s ok but your muffler on a chainsaw needs a catalytic converters.
jacob j.
Only the weird
11:02 PM
Coastal Oregon
CrystalRiver1
1:02 AM
Alabama
Speaking of drugs contributing to delusional reasoning...take a look at this ad!
Not to mention he's a "Gabby Gator!":deal::squezer:
STIHL 026 PRO CHAINSAW - $450 (Hiram)
https://atlanta.craigslist.org/wat/tls/d/stihl-026-pro-chainsaw/6714061993.html
condition: like new
make / manufacturer: stihl
model name / number: 026 pro
size / dimensions: 18"
more ads by this user
I have a stihl 026 pro with an 18" bar in excellent condition. I'm letting it go for a steal at $450.00 OBO.
The power of a professional-grade chainsaw is right at your fingertips with the Stihl 026 pro. This chainsaw has been designed to be completely user-friendly. Anyone from pros to amateurs can handle this durable, robust outdoor tool and operate it with relative efficiency. The 026 pro is also easy to carry with an overall weight of 10.6 pounds. It has a total output of 2600 W. This power-to-weight ratio helps balance everything out. The saw, which runs on gas, also has a 50.2 cc engine displacement. It carries strong sawing power in a small, light package. This 026 pro has a number of the standard features that accommodate users and make a job simpler. For one, it has the ElastoStart, a dampening feature that absorbs and releases force. The alternation between absorbing and releasing force results in a smoother start of the engines. The starting system in the saw also contains a decompression valve which further reduces the compression pressure. It also eases the effort that is required when pulling the string. For this to work, you must manually press it prior to starting. It closes on its own.The chainsaw features an anti-vibration system. This minimizes the transfer of vibrations of the engine and the chain to each handle. With this transfer lessened, the saw runs effortlessly. Users may find themselves working longer without sacrificing strength. The Stihl 026 pro has an Ematic System with an Ematic bar or Ematic S guide bar. This reduces the amount of lubricant needed for the chain by up to 50% depending on cutting attachment and wood. The system helps each drop of lubricant oil get to the right spot rather than being wasted. Each Stihl saw can be run across seasons thanks to the carburetor heating system. Simply change the chainsaw from summer to winter and air intake pre-heats, keeping the carburetor from icing up. Another important part of equipment in these saws is the compensator in the carburetor. This keeps the mixture of fuel and air from becoming too rich as the air filter clogs up. The ratio is kept more constant and the filter cleaning can wait until the saw power considerably drops. When it comes to fuel, the design of these Stihls allows you to see right into the tank. This way, you always know whether your Stihl saw is full or needs more gasoline even while it's still running. Also, the caps open and close quickly and without the use of any extra tools. The Stihl saw models also give you more control over the distribution of oil. It has a controlled-delivery pump built in to allow you to select the right amount of oil required for individual jobs.Accessing all of the controls on the Stihl 026 pro chainsaws is made convenient. The start, stop, and a number of other important functions can be found on a single-lever type master control. In addition to making jobs a cinch to complete, other features in the Stihl 026 pro focus on safety as well. It has a side-mounted chain tensioning, making it safer to tension the chain and blade without disassembling the entire saw. The model also has an improved air filter system so that users are exposed to fewer gasoline fumes.
Brand: STIHL
Model: 026 pro
Product Key Features
Power Source: Gas
Features: Front-Hand Guard, Side-mounted chain tensioner, Air Injection, Quick-release air filter, Anti-Vibration Handle, Chain Brake
Type: Arborist Chainsaw
  • do NOT contact me with unsolicited services or offers
