lovin-J-reds
OPE Member
- 3:18 AM
- Nov 3, 2021
- Frankiln NH
Dude...
-if u wanna make a stock saw run like a m-fer, then you need nitrous.
-if you wanna cut firewood fast, get ur saw ported.
-if you wanna race, you need something other than a 2050 bro.
Its all I got thats the *s-word saw. It was a parts saw and got all my parts and got it to run. I also dont want to spend $500 for a bottle
I would love to try a turbo on the saw but I can't find the right size, I'm thinking the GT0632SZ which is the smallest turbo Garrett makes but I think it to big?
View attachment 332856 Are you gonna be satisfied with three cuts then shutdown till its cool enough for three more? You are gonna need a plug that looks like this..no porcelain shows when viewed from the side. Short ground strap. Pick up a few.
Ya I was only gonna run the saw for a min then let it chill and try some more. Whats the advantage with that plug, what does it do?
Klotz makes a few different oils that are compatible with alcohol, nitromethane, and gas, but some of those oils do not mix with some gas only oils.
Remote controlled models run on methanol and nitro, so they make fuel line as small as you need and smaller. Silicone is what they use, but it will expand and disconnect from fittings if exposed to gasoline.
I feel stupid now, I never even thought about the rc fuel lines. I got a couple rolls of it. I need to find a castor oil to mix with methane
Thanks for all the responses
