- 11:11 PM
- Jan 24, 2018
- Extreme Southeast CA
Great job , davidwyby
Yessir…View attachment 421187
I was unaware that Amsoil was in the industrial lubricants game until this afternoon....
Generic way & axis lubricant and cleaner/flush.View attachment 421187
It is a "single use oil", but it does well keeping friction surfaces clean and lubricated.
I have used that "68 stuff" from multiple manufacturers , other than added color and perfume in the more expensive versions there is no noticeable difference.
With the purpose of this oil just make sure Your machines central lubrication unit works properly and that the return flow prevention valves are functional.
Doesn't than imply that Your maintenance guy should have figured out by now how much oil is spent a month on average and order by default as many buckets or barrels You need every 4 months?
Yeah, now I feel bad about part of my previous post!In this instance I'm going to defend our lone maintenance man, who is trying to hold together all the equipment and the building, in a buisness employing 60 people, while he has been actively battling cancer. Ordinarily, it's easy to point fingers, but I'm giving him a pass this time around.
The same people who take the last bucket also use the last of the TP in the bathrooms.... The lack of consideration for the next guy/gal seems to be universal
I gave hot "blackening" a try.
I used mineral oil (instead of beeswax & linseed oil) and I did not get my IR-gun to check temps (400°F) which may have contributed to my mediocre results.
Any of You metalheads ever mess with hot blackening steel?
Other than for aesthetics & looks is it even worth the trouble considering it will rust anyway?
Thanks!I've never tried hot blackening but I've done lots of oil quenching for hardening tool steel. I don't use oil as it leave the part covered in suit, instead I'll use mineral spirits or gasoline. Just have something ready to cover over the top to snuff the fire out it it lights up.
The results look pretty decent to me.
We use Tweco ground clamps at work. These are rated 200-500 amps, but would work very well.I need to change the welders ground clamp.
This is not adequate for 120 Amps!
