The Chainsaw Pic Thread
Elim
S=D/T
11:26 AM
West Virginia
Yeah. Clearly someone did not think that one all the way through. Ah well... I am sure you don't use the name plate to figure out what side of the saw you should be on anyway.
mdavlee
Hillbilly grinder
11:26 AM
TN
Sent from my 0PJA2 using Tapatalk
Nice old collection. I've always wanted to run some of the older 995 and 3100G. I've got to run 1130G and 1050, 2100s, and more of the common ones.
P.M.P.
Stiff Member
11:26 AM
Michigan
Hey everyone sorry to mislead anyone I was wrong on the 044 being a 10mm its a early 12mm with angled finn. I got a private message from another member here telling me about his that he had a angled finn 12mm with the heated handle.I assumed all the angle finns were 10mm:BangHead:.I never checked the serial # till other day. I did some research to find ot where the # was located it was covered in grime.The serial # is 131915xxx .I got saw couple months back it came with a case has a lightly scored piston got a air leak needs to be torn down and redone.I never really took the time to look into it just thought it is what it is. CARRY ON
Definitive Dave
Piss Rev Mafia Member
11:26 AM
Central Ohio
I would be interested to know what markings are on the jug, I am a nerd in this way :)
Dave
P.M.P.
Stiff Member
11:26 AM
Michigan
Curious as to what these making are above spark plug casting?
N
NewToStihl
Guest
Ooohhhh! I've heard theories as to what the stamped letter means, but with no hard evidence I'm not going to repeat them. I'm really curious as to what our local experts know about that as I've always wanted to know the truth. :icon_popcorn:
Definitive Dave
11:26 AM
Central Ohio
I believe the A and numbers on top center are bore tightness for original piston fitting
There are likely more numbers letters and perhaps plus signs on the sides of the base that denote casting, revision and mold series
