- 4:23 PM
- May 30, 2022
- NW MT
I gave up on them, I am going to wait until spring time, and then come up with a plan
You better head out there and give him a hand so we don’t have to wait for pics. Take your trailer!We have to wait until spring for pics?! ;-D
Don’t tempt meYou better head out there and give him a hand so we don’t have to wait for pics. Take your trailer!
next moth I will move back up to homestead property and stare at until I muster up the confidence to take a saw to it, I cut firewood selectively from my property and 24 inch dbh trees I can confidently trip them where I want them to go, there is this leaner and another I would like to remove this year.I’d just say…. Invite some crazy ope members for a gtg
But really I can’t see much in them pics to even figure out what the best thing to do is…
I think you’ve had the advice before ( ratchet strap, small face cut, and bore cut, then release it with the final tickle from the back and run for it..
There are so many ways to deal with learners,… like I said before invite someone and learn from them ( or not )![]()
Been there. Had a 20" red oak with a big sweep in it(read 6-8' sweep), then the wind came along and gave it a nudge so the top was about 20' out from the base. I made a very small notch and then bore cut it from the high side(would have at least bored it half way from the low side but there was a save tree about 12" from it), I managed to get about 2/3 in before cutting the stress cracks loose and the door was instantly closed. I had no idea there were cracks in it because the root plate had lifted, but once it was down it was easily seen, ie, hindsight is 2020 lol. Fortunately I was able to grab another saw a pull the powerhead and did everything exactly the same although above the previous cuts and also made my bore cut much wider and got it down no problem. When I went to cut my bar out of the stump thee was still enough tension that I couldn't cut from the back straight out the front without opening the cut up wider. Its amazing how much tension they can have in them.Also if that tree is split it may pinch when you are in the cut. That's the sketchy part.
C4 works well.I think dynamite and a long fuse would be just the thing for those trees. Plus, they'll already be split into firewood pieces when (if?) they hit the ground!
