T540xp woes
av8or3
6:31 PM
Waleska,Ga.
Can you build the carburetor on this saw just like any other? Doesn’t want to stay running. Replaced the tank because it was dropped and the gas remaining smelled funky.
I can only get it to hit some. Choke, WOT, idle it will only hit and putter at best.
PA Dan
FYD
6:31 PM
White Oak PA
Yes you can rebuild it. I went through 3 of them. Did the carb, impulse line, fuel line and filter. Have the carb updated at a dealer. The impulse line is an issue on a lot of them. Check that for sure!
av8or3
6:31 PM
Waleska,Ga.
Compression feels good.
tickbitintn
5:31 PM
middle tn
I had one that I thought was fuel system issues. Went through it and everything looked fine. Would sputter on choke and only run with throttle, no low end.
Turned out to have about 60#'s of compression.
tickbitintn
5:31 PM
middle tn
It had "impact damage" to start with. Upon replacement of broken parts the running condition was found.
Turns out it was thrown out of a tree because it would not run right.
Backtroller
5:31 PM
Land of Badgers
I would have liked to thrown the one I had out of a tree while working on it. The little tabs broke off while assembling grr. Ran great once I got it back together. Just didn’t like how it felt.
Creaky limb tree care
11:31 PM
Wales UK
Nine times out of ten it's the piston ring that's worn, affecting compression.
(Rebuilt lots of these with this fault, they all felt like compression was ok!)
