Sure you know what you have just mixed !!
mdavlee
Hillbilly grinder
1:24 PM
TN
View attachment 22174 My point is all about the Lack of accuracy in a vestle that some may be using as a base line . There is a thread running all about what 2 stroke oil is best..... BUT if you think you are mixing the correct 40.1 , 45.1 or 50.1 ratio then you need to have a container that IS correct regardless of what oil you chose !
From a 16-18 % inaccuracy with the raw petrol , the mix I would get from the sort of 1 ltr ..2 stroke mix bottles i tried, would be WAY out !
Is this from the pump as well? I usually fill 1 gallon jugs from bigger ones and have them all marked out with 1 gallon from the pump. I add 4 Oz of oil per gallon or real close so I'm not worried baput not having enough oil in there anyway.
Simondo
6:24 PM
UK
No sir...my post is to only draw attention to the "posable" situation with 1 ltr mixing bottles that some may not be aware of . I Mix my fuel in small amounts so as to be sure it is never around long and i can rely on its integrity in a customers machine when testing after working on it.
I assumed the bottles were accurate and found not...bought a lab beaker measure as a datum.
mdavlee
Hillbilly grinder
1:24 PM
TN
I go through a good bit of mix in saws I port. I won't drain the tank back into my jugs so it's usually dumped into the waste oil. All the local saws I get I drain right away.
