Stroking a Dolmar 7900
Terry Syd
2:45 AM
Comboyne, NSW Australia
Poleman already demonstrated that the HD-12 was inferior to the modded Zama twin jet (big time!) on a 7900. However, I know you have been working with the HDs - eliminating the EPA circuit and the like.
I spent a heap of time dialing in the HD-5 on my modded 029. The HD can be done, it just a bugger of a bunch of work. The Zama is a piece of cake compared and it will still have a better idle circuit than an HD.
The HD looks like it has the potential to flow more than the Zama. Having said that, most of the restrictions in the intake tract come down to the bottle neck of the air filter.
If you can get two HS-12s, you could block off the EPA circuit on both, then start opening up the auxiliary jet. First one at .35mm and the other at .4mm. See what works best and then go from there.
12:45 PM
I bought one of the new wj71 394 carbs they were selling on eBay for 40$ a while back and put a rwj top plate on it for impulse (straight swap), and a few mods to get it to work on a 385/390. It tuned very well. Should work on a 7900, might have to mod the throttle cable stuff/turn the boot?
Marshy
WFO Cutting
12:45 PM
Mexico NY
I'll compare later but looks like throttle cable placement is perfect. I'm hoping for direct swap on the WJ70.
Fruecrue
certified hand catcher
12:45 PM
Alden NY
I remember reading somewhere that the RWJ Venturi is larger than 385/390 carbs.
Anyone know how a 394 carb stacks up?
Seems I need one now....for science.
Lightning Performance
12:45 PM
East of Philly
Made it to page five. Too nice to sit here longer today. So many good threads on engine specs/builds here. Looking forward to building up and retooling a shop for bench work again. You guys keep my head in the game.
12:45 PM
Venturi is 18.25 in the wj71 and 18.45 on the wj39. Rwj is like 19 I think. The jetting is richer on the 394 and 385/390/395 carbs. Wasn’t a fan of the rwj on a ported 385, the tilly behaved better.
srcarr52
12:45 PM
Iowa City
Tilly 298 is plug and play Dave.
If the HS298 is plug and play then the 394 based carbs (WJ39, 70, 71) are going to have a throttle shaft that sticks too far out. The throttle pull is about 1/4" further out on the 394 carbs than the 395 carbs, this causes the throttle cable to run at too much of an angle and it gets caught up.
I've adapted a 394 carb to work on the 395 but I had to recess the carb body for the return spring to shorten the throttle shaft enough.
Fruecrue
12:45 PM
Alden NY
Jetting can be changed. I’m thinking move as much air as possible and match fuel to that is the way to make power.
Fruecrue
12:45 PM
Alden NY
Good info thanks Shaun.
Intoxsawcated
9:45 AM
Idaho
Has anyone messed with an RWJ-5 over a RWJ-4?
Sent from my SM-S767VL using Tapatalk
