Stihlms660magnum
OPE Member
- 4:09 AM
- Jun 9, 2023
- Sandy, OR, USA
Need to know if you can run a 661 cylinder and piston on a 660mag or carb?
Oh, okay. I just did some work to my 66 I went from a wj69 to a wj10a which has a bigger jet. And I bored out the barrel of the carb, runs way stronger and better so I’m gonna leave it for now until I get it portedThe only thing that swaps between those 2 is a couple of the screws. Maybe some clutch parts
On an MS660? 56 vs 54mm. Piston will not fit.I think you can run a 395 piston in it I would have to bore the cylinder not completely sure.
I know that on the stalk cylinder. It would fit if it’s bored and replated I’m just not sure about the connecting rod length on if the piston will hit the top.On an MS660? 56 vs 54mm. Piston will not fit.
Please let everyone know who will replateI know that on the stalk cylinder. It would fit if it’s bored and replated I’m just not sure about the connecting rod length on if the piston will hit the top.
I know. Where I’m at it’s 180$ to have it replatedPlease let everyone know who will replate
The cylinder for you, that part could be extremely difficult and $$$
180$ aint bad if you've got a rare Remington cylinder or an heirloom saw.I know. Where I’m at it’s 180$ to have it replated
US chrome180$ aint bad if you've got a rare Remington cylinder or an heirloom saw.
Who does them for you?
Yeah, I’m not sure if I should do it. As it is rn it runs pristine and I’ve raced with it already a I beat several modded saws as mine is still stockFwiw, ran pretty good. But a 54mm OEM jug with an oem piston whooped its ass. No fingers or nothin. @mdavlee recipe.
Saw is still running well. You cannot beat oem transfer tunnels. Sow’s ear vs silk purse kinda stuff. In the end, I timed the ex near 100 and shulda been on the 95 range.
Remember that once you bore a jug out, you reduce transfer tunnel area. Part of why big bores run shítty. At $180, you are at a bargain though.
file:///var/mobile/Library/SMS/Attachments/fb/11/ED9EC946-6BEA-4E13-97EB-A22D2BDA2880/IMG_1223.MOVYeah, I’m not sure if I should do it. As it is rn it runs pristine and I’ve raced with it already a I beat several modded saws as mine is still stock
