hl supply has a knock off version of both that's not too pricey...that being said..im not a big fan of rhe stihl seal toolLooking for a seal puller. Ive tried the screwdriver trick and it sucks.
Also need a crank case splitter as well. Thanks
exactly the stihl seal pullers suck dick i use a stihl tuning scredriver with a groove filed into the side of it and grip the shaft of it with sidecuts and pryhl supply has a knock off version of both that's not too pricey...that being said..im not a big fan of rhe stihl seal tool
little heat..little lube...tap the metal IN to loosen bond...and they usually come out with little fanfare...exactly the stihl seal pullers suck dick i use a stihl tuning scredriver with a groove filed into the side of it and grip the shaft of it with sidecuts and pry
i havent used my seal puller for a couple years and it just sits
lol I would if I knew what I had in it and found a suckerYou should get rid of that pos
lol you would be disappointed in them and I’d have to refund your moneyLook me and you go back a long time. Almost 3 months. I will help you out and offer 20 bucks...
Ok, so I'm NOT the only one that thinks that seal puller is a P.O.S.
I got the HL Supply/Farmertech whatever one, no instructions, all those different puller arms, missing hardware, get it all set up and those stupid arms just keep slipping past the seals.
Even the chinese one wasn't cheap.
it really is a good copy. I got to believe I do NOT understand how its used correctly because I can't get mine to do Xhit. I have asked MANY times how-to set the "Jaws" but to no avail...not a single vid of it in use or how the jaws are used.... I will claim ignorance on this tools use.Ok...I guess i will take that exact one out my cart.
Anybody have and LIKE the Husky seal tool ? Much cheaper... not gonna work with 026/200t sized stuff though
I bought the Lisle version. They look identical. It comes with 2 hooks so I took 1 and ground it a little shorter. Seems to work fine so far, but I’ve only used it a few times.
too small for the FW side 026 seal.the stihl tool works fineI bought the Lisle version. They look identical. It comes with 2 hooks so I took 1 and ground it a little shorter. Seems to work fine so far, but I’ve only used it a few times.
I got it off eBay and was almost 200 bucksI've used the seal puller many, many times. I pulled off those cheap butterfly nuts and replaced them with torx. Gives me more bite into the seal. Works every time. And you,'ve got to go into the ipl for the number on the stihl seals at least. Dalls right, it was pricey but worth it in my case.
stihlIs yours made by stihl or aftermarket?
