Stihl S10 Parts Help
Eagle1899
1:45 PM
Central Minnesota
I am in the process of working on a few saws (262XP and a 372XP Chusky kit saw). When I get those done a mechanical restoration is due on my Stihl S10. After looking around a bit... parts are scarce.
I was hoping some one can help me with some part numbers and sources.
Mainly:
Crank seals and bearings
Case gasket
Cylinder base gasket
Ignition points
Ring size thickness for possible Caber match up (not sure if it is a 44mm or 47mm)
Thanks in advance!!!
Trever
nohoff
professional flusher
6:45 PM
Germany
Look for the stihl 08s they have the same crankcase and cylinder.
Ignition should be the same too.
Only difference should be the Handle and carb.
bulletpruf
6:45 PM
San Antonio, TX
Got an S10 refurb in my future, too. Glad to hear they share some bits with the 08.
PogoInTheWoods
1:45 PM
Ohio
Basically the same saw. Also share parts with several other units including the TS350 chop saw. Here is a very early Clymer service manual that is actually pretty handy for the basic overview..., and I stress basic.
Crank seals and bearings - Seals: 9640-003-1610 (both sides) Bearings: 9500-003-0341 (both sides) and are actually 6202's.
Case gasket - 1108-029-0500
Cylinder base gasket - 1108-020-2300 (for either cylinder)
Ignition points - 1115-400-2000
Ring size thickness for possible Caber match up (not sure if it is a 44mm or 47mm) - 1.5mm for either diameter
PogoInTheWoods
1:45 PM
Ohio
nohoff
6:45 PM
Germany
This IPL isnt german.
Seems like swedish or norwegian.
Here is the german ipl with the proper parts #s.
