Stihl MS462 cylinder base cut
Moparmyway
Its just a saw
6:21 AM
In a meeting
I can say that even counting set up, this not only did a better job, it was much faster than by hand checking it a hundred times with a straightedge.
Do you fellas find the need to relieve the ramp and top of cylinder extension as well?
Edit: After fooling around with it, I ended up going back to basics and took off as much as the base.
Whatever I take off the base.....I take off the cylinder extensions.
So, just echoing/piggybacking Docs question, the tapered extension was hand cut after the lathe operation, yes ?
What about the longest part of the extension, was that cut with the lathe or hand cut ?
5:21 AM
I cut the flat part of the extension is cut while the jug is mounted for the squish cut. The angled part I cut by hand.
qurotro
Cookie Cutter
5:21 AM
Ar
The extension is for the piston support I guess. Pisto is longer on the intake side?
5:21 AM
Just like Randy said...
I'm thought about it......just because it sucks. But......
Fortunately it's the only thing that does about this saw.
