Stihl MS462 cylinder base cut
Member
11:30 AM
Great work Steve.
Do you fellas find the need to relieve the ramp and top of cylinder extension as well?
Gotta say, much cleaner than the hand method I’ve been using.
Thanks Doc,
The case is machined right there, clearance can be checked quite easily with the backside of a calipers.
Edit: After fooling around with it, I ended up going back to basics and took off as much as the base.
dustinwilt68
Wilt Built Work Saws
12:30 PM
Southwest PA
Just thinking, if using the band cut setup, the bolts holding the cylinder might get in the way of turning the cylinder in 2 of the corners as well, plus like a few said it wouldn't be as rigid, I like the idea of undercutting a mandrel at the proper depth of where you want to remove material.
Member
11:30 AM
Reminds me of what an old machinist told me about lathe work, "The tool you need most, is the tool you make"
Seems to come to fruition quite often in my works.
