A member on AS wrote this, I think he knows a lot about 2 strokes:
I want to put to bed the myth of high compression in chainsaws,having worked on 2 stroke racing engines since the 70's I want to lay some straight facts down. High compression was first made popular during the 60's with big v-8 racing engines(4-stroke) and compression ratios went up to 13-1 or more. But the best 2-stroke racing engines actually reduced the compression ratio from the stock engines. Why,because the more the compression ratio the more horsepower it takes from the engine to crank the engine against that high compression,at some rpm the HP taken to crank that high compression takes more HP than it makes,and then the engine starts to lose HP. Thats why a factory motor making 60 HP at 8.5-1 compression,makes 100HP at 7.5-1 comp. ratio.
Now higher compression does make more power at low and mid range power for sure,but not many saws run in that range. so if you want more low end or mid range power compression is good,but if you need high rpm race power high compression will simply cost you Hp. As my instructor told me in 1975 "high compression fights high rpms",he was right.
So more more compression can help you,but not at high rpm's.
When you yank the cyl. gasket out of a saw you do gain some compression,BUT you also lower the exhaust and transfer ports down,reducing their duration,and reducing higher rpm power. I would much prefer to raise ports than compression for power,much more can be gained.
In many engines I would much prefer to raise the exhaust port and lose compression,I know I will make much more top end power.
Removing the cyl. gasket and lowering the transfer ports is really bad,you reduce their duration and reduce their open time from tens of thousanths of a second to even less!
what do u guys think about that?
Before I read this, I want to make a bgd but now I’m not sure if it is worth the time.
