Stihl Durocut Head on a Husky Trimmer, will it work?
3browns
10:05 AM
Fishhook, Alaska
Anyone know if a Stihl Durocut 20-2 trimmer head will fit on a Husky 322L trimmer?
I am fighting bunch grass that shreds .095 and .105 line like nothing
A friend has an old fixed line head running .130 line and it lasts way longer so that's what I am trying to duplicate
Thanks in advance
Steve
Excellence!
1:05 PM
You could put a grass blade on there. Thats what i use on my 223L in grass thats hard on string.
3browns
10:05 AM
Fishhook, Alaska
I appreciate the input but unfortunately next to every clump of bunchgrass is a lava rock or 3
Nobody here uses blades except in situations where there is established landscaping
My property is thinly scraped over dolomite and volcanic rock, red dirt, bunch grass, and Kiawe/Mesquite trees
I am just trying to knock down the grass until we can get started on permanent landscaping
Thanks
Steve
Excellence!
1:05 PM
Thanks
Yikes! Yep, you would tear up a blade pretty quick.
Have you tried Oregon gatorline magnum? I use that if i cant get a blade in there. Holds up real well.
3browns
10:05 AM
Fishhook, Alaska
No, I haven't tried that line
I ran a 250' spool of each of the following: Husky Titanium Force, Desert Cyclone, ACE Hardware/Arnold Professional Extreme
All was soaked in water for at least 48 hours prior to running
The ACE/Arnold lasted the longest but even that was quickly destroyed
My friend has an ancient trimmer and as I said has a 2 line head that holds up to .130
He runs plain black Stihl round in .130 and just cuts and cuts while I am changing line
Frustrating
I have an Echo SRM-225 in Alaska and can take on some pretty mean raspberries, etc and .095 line holds up decently
Here in Hawaii in my application it's worthless
I have seen a couple of other "push in" type heads that will take .130 line
They are universal and I know they will fit
I just figured the Stihl head might be better/stronger/etc
Sorry for the long rant and thanks for listening
Steve
Excellence!
1:05 PM
The husqvarna tiatanium line sucks! Try some gatorline magnum. Its comes in square or round. The square is more agressive cutting. Has an outer jacket around a very hard almost steel core that holds up very well for stemmy woody grasses and brush. I use 095 with good results. 105 would probably make you happy. Get you some! :D
3browns
10:05 AM
Fishhook, Alaska
Ditto on the Husky line sucking
Absolutely garbage
I will get some Gator line and give it a go
Thanks again and cheers!!!
AVB
1:05 PM
Pluto
I am fairly certain 20-2 will not fit due that it is for a 8mm setup and the Husky is a 10mm setup.
3browns
10:05 AM
Fishhook, Alaska
Well I kind of figured it would be proprietary to Stihl
The universal ones all look oversized with a multitude of adapters, sleeves, nuts, etc
It might be as simple as boring the I.D. of the Stihl head but not sure I want to mess with that
Thanks
3browns
10:05 AM
Fishhook, Alaska
Well it took a while but I finally got some .105 square magnum gator line
This stuff ROCKS
I gave it a good soak and spooled up 15’
It barely fit and I KNEW it was never going to feed out of that piece of crap Hooski head...
But it did and as easily as any line I have tried
And boy is it tough
Wicked tough
I sooooo appreciate the tip on this line
I do need to mod my muffler now because this 322 L will barely spin a full span of this line but it needed it anyway
thanks again
Steve
Excellence!
1:05 PM
This stuff ROCKS
And boy is it tough
Wicked tough
thanks again
Thats great! Glad its working well. The 095 is pretty tuff to. Will definitely be eaiser on the trimmer.
